Poll
Was this addon useful to you?
Yes it was, thank you :)
21 (95.5%)
No, try better next time! :(
1 (4.5%)
Total Members Voted: 0
Author Topic: Last Joined Check [1.05v]  (Read 70977 times)
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
Re: Last Joined Check [1.04v]
« Reply #30 on: August 09, 2018, 12:29:30 pm »
It doesn't work, even the command itself... It's weird, since i have the same code here without errors, also checking those lines i didn't find anything uncommon...
[ERROR] lua/autorun/sv_lastjoin.lua:221: 'end' expected (to close 'function' at line 155) near 'elseif'
  1. unknown - lua/autorun/sv_lastjoin.lua:0
[ERROR] lua/autorun/sv_lastjoin.lua:176: 'end' expected (to close 'function' at line 155) near 'elseif'
Yeah, I don't mess around with Garry's Mod anymore, and I don't have a proper code editor anymore. I opened it on my old laptop that I used to use for coding and found the issue, I copied and pasted in the wrong area, and forgot about an end statement.
 This will work now.
Re: Last Joined Check [1.05v]
« Reply #31 on: August 09, 2018, 12:33:48 pm »
Updated to 1.05
-Fixed !ocheckjoin STEAMID
Offline Shu | Pexie
  • Polyglot guy here!
« Reply #32 on: August 09, 2018, 03:20:33 pm »
Updated to 1.05
Everything is working now, but since you are here.... You can tell me about the string called "tostring(timesjoined)" means. The first time i saw this, i was thinking it had something related of how many seconds you were in the server (after authentication), but probably i'm wrong about it...
« Last Edit: August 09, 2018, 03:25:40 pm by Shu | Pexie »
« Reply #33 on: August 09, 2018, 06:25:35 pm »
pretty sure it just lets the user or other people know how many times they joined the server. If I recall it's a number in parentheses (x)
Offline Shu | Pexie
« Reply #34 on: August 09, 2018, 10:23:18 pm »
Yeah now that you said, it makes sense... Anyway thanks for the help and the update after years later  ;)
