Author Topic: Deathrun maps broken?  (Read 19864 times)
Offline Canne
Re: Deathrun maps broken?
« Reply #15 on: April 13, 2015, 09:49:57 am »
You don't want to disable them, you want to keep them.  Your server is already removing them.  It seems related to your problem.
Soo what can i do to fix this there is ton of errrors yea but none of them are doing anything with my server at all it's just the wall that don't break balls that suposed to break and glasss and wood in couple maps like Helix the balls won't break they stay there like Rooftop there is a glass that is suposed to break when you hit it so you can pass it and a big wooden wall also on other maps stuff like that happen so people wont be able to passs them ... :/
« Reply #16 on: April 13, 2015, 07:40:58 pm »
We've told you our suggestion for troubleshooting.
Start with no addons or workshop subscriptions.
None.
Only DeathRun, and see if it still works.
If it doesn't, ask/find where support for the DeathRun gamemode is. Surely someone has come across your challenge.
Make sure there hasn't been a deathrun update since the Gmod updates over the past month.
If it does, start adding back addons 2-3 at a time.
Try again, when it breaks, you know it was in the last 2-3
I'd be asking in whatever community supports DeathRun game mode.
Surely there is one somewhere, and perhaps they've seen this exact same issue.
Until you brought it up, I'd not ever heard of Deathrun, nor know if it was updated after the Gmod update broke many things last month.
