Immunity problems
Topic: Immunity problems (Read 7588 times)
Megiddo
Ulysses Team Member
Project Lead
Immunity problems
May 03, 2007, 11:50:03 am »
Okay, I fixed the immunity problem for ulx psay in ULX 3.10 (can't talk to immune players). Were there any other commands like this?
Thanks all!
Avien
Full Member
Re: Immunity problems
May 03, 2007, 07:31:16 pm »
This may not be one, but i noticed that admin talk can be used by regular people when they use @. Not sure if they can see what the admins are saying, but they can still use it. Unless that was meant to replace psay for admins for the time being?
Megiddo
Ulysses Team Member
Project Lead
Reply #2 on:
May 03, 2007, 07:34:57 pm »
It's so anyone can talk to the admins. IE, if you want to tell the admins that you think someone's cheating (and obviously you don't want the cheater to hear).
In short, yes, it works how it's supposed to.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #3 on:
May 03, 2007, 07:52:14 pm »
And, no, non-admins can't see what people are saying using @, unless they are the non-admin saying it.
Last Edit: May 03, 2007, 08:01:24 pm by JamminR
Physcho Killer
Reply #4 on:
May 13, 2007, 01:28:37 pm »
on my server when i adduser "test" "admin" no" or "yes" they are always immune y???
Megiddo
Ulysses Team Member
Project Lead
Reply #5 on:
May 13, 2007, 03:01:23 pm »
Because it accepts 0, 1, or nil.
Avien
Full Member
Reply #6 on:
May 13, 2007, 08:23:55 pm »
I swear i used adduser "test" "superadmin" "immunity" once and it worked...or was i just dreaming?
Is there a way to edit the immunity that people get? Someone tried to bring me to them, and he couldn't, it said i was immune. Or does immunity only work on those that are lower then you?
spbogie
Ulysses Team Member
Sr. Member
Reply #7 on:
May 14, 2007, 01:00:48 pm »
I believe any non-nil, non-zero value will equate to true for immunity.
Immunity applies to any command that would directly affect you. SuperAdmins override immunity, and immunity does not affect if you are targeting yourself.
Immunity problems
