Author Topic: Gmod 9 Propprotection! help!!!  (Read 6507 times)
Offline nielscorn
« on: May 05, 2007, 11:16:15 am »
I'm having a hard time finding a propprotection for my server, i have everything installed here and it works on  my server (gmod 9.0.4)
But i really need a propprotecter.lua  for my server, i've seen many people have it...
could someone show me where i can download or could you give me the code that i have to put in a lua script and where to put it please?... also an anti spawn lua code would be awesome.
thanks in advance!
Offline nielscorn
Re: Gmod 9 Propprotection! help!!!
« Reply #1 on: May 05, 2007, 02:48:10 pm »
Edit: Invalid input...
« Last Edit: May 06, 2007, 02:06:57 am by nielscorn »
« Reply #2 on: May 05, 2007, 08:38:35 pm »
Nielscorn, we appreciate your newness, but please realize this rorum is a bit, no, make that much quieter than other forums you might be used to.
Especially right before a new release like today.
If you have a valid question, I suggest waiting 24 to 48 hours before even considering adding any more input.
In fact, the input you gave isn't helpful, and more often than not, aggrivates people and might make any help they might have given go un-posted.
That being said, using our wonderful forum search function, I found this post for you.
/index.php/topic,786.0.html
Please, ask smarter, not harder.
Thanks.
Offline nielscorn
« Reply #3 on: May 06, 2007, 02:06:11 am »
Thanks.
Thank you for that wonderfull explaination and i will consider those things you said, i will but before you give me a link to a topic(i know you only tried to help) and say i don't use the search function(i'm pretty offended by that because i ALWAYS use the search function first) and i already noticed that topic and i already clicked those links... but where do i end up? at www.google.com, so after this post i had to try again and copy pasted those links and then they worked.Thank you for responding to my post and i will just check occasionaly here thank you.
« Last Edit: May 06, 2007, 02:09:34 am by nielscorn »
« Reply #4 on: May 06, 2007, 08:37:45 am »
Nielscorn;
Offending you was not the intent.
Showing that using Google Search to find Gmod9 plugin content when it wasn't written/hosted by Team Ulysses (and therefore, not available from our forums) was.
You didn't mention that you'd tried other posts. Had I known, I would have keyed you in to the text of the link too.
Zyklus and I found the links that we posted in text using Google Search.
We were being cheeky and linked to Google, but posted the full link in text.
The one he posted either went down after he found it, or he didn't test it once he found it at Google.
Either way, Avon's Prop Protect is what I used when I had Gmod9. It's a good package.
