Author Topic: Command not wqorking  (Read 5721 times)
Offline Unknown Gamer
    • TrueKnife TTT
« on: April 11, 2015, 01:35:20 pm »
So Im redoing my command since for some reason it got deleted but the command is not working. I do not know what is wrong with it right now
  1. CATEGORY_NAME = "BDG Commands"
  2.
  3. function ulx.hopper()
  4.         if SERVER then
  5.             util.AddNetworkString("cl_openserverhoppermenu") -- long name to prevent conflicts
  6.         end
  7.
  8.         if CLIENT then
  9.             net.Receive("cl_openserverhoppermenu",
  10.             function (ply)
  11.                 RunConsoleCommand("serverhopping")
  12.             end)
  13.         end
  14.
  15.         function ulx.hopper(calling_ply)
  16.             net.Start("cl_openserverhoppermenu")
  17.             net.Send(calling_ply)
  18.         end
  19. end
  20. local hopper = ulx.command( CATEGORY_NAME, "ulx hopper", ulx.hopper, "!servers", "hop" )
  21. hopper:defaultAccess( ULib.ACCESS_ALL )
  22. hopper:help( "Switch between our servers" )
  23.
Newb Coder. Soon to get better
Re: Command not wqorking
« Reply #1 on: April 11, 2015, 04:59:20 pm »
What's it supposed to be doing and what doesn't it do?
Offline Zoeo
« Reply #2 on: April 11, 2015, 05:13:06 pm »
I think this is a server hopper that will allow you to switch servers using a menu? Not sure but he can correct me.
« Reply #3 on: April 11, 2015, 10:03:50 pm »
Why do you have two ulx.hopper functions?  That is your entire problem.  Fix that and it should work.
« Reply #4 on: April 11, 2015, 10:36:02 pm »
Good catch. Functions in lua are first class, so by defining the function inside the function, you're essentially overriding it and it won't work.
    • TrueKnife TTT
« Reply #5 on: April 12, 2015, 06:41:18 am »
Im am probably the most blind person on this planet. Thanks Guys
    • TrueKnife TTT
« Reply #6 on: April 12, 2015, 06:48:05 am »
AGH! Still not working
  2. if SERVER then
  3.     util.AddNetworkString("cl_openserverhoppermenu") -- long name to prevent conflicts
  4. end
  5.
  6. if CLIENT then
  7.     net.Receive("cl_openserverhoppermenu",
  8.     function (ply)
  9.         RunConsoleCommand("serverhopping")
  10.     end)
  11. end
  12.
  13. function ulx.hopper(calling_ply)
  14.     net.Start("cl_openserverhoppermenu")
  15.     net.Send(calling_ply)
  16. end
  17. local hopper = ulx.command( CATEGORY_NAME, "ulx hopper", ulx.hopper, "!servers", "hop" )
  18. hopper:defaultAccess( ULib.ACCESS_ALL )
  19. hopper:help( "Switch between our servers" )
Offline Livaco
    • Livaco
« Reply #7 on: April 12, 2015, 09:46:28 am »
Put The Funtian Above If Server
Example
Now
if SERVER then
if CLIENT then
    function (ply)
    end)
Correct
if SERVER then
if CLIENT then
    function (ply)
    end)
Thats What It Would Be I Think
My Website
My Addons
PermaBanV1.0
Livaco Products©
    • TrueKnife TTT
« Reply #8 on: April 12, 2015, 10:03:43 am »
Example
Now
if SERVER then
if CLIENT then
    function (ply)
    end)
Correct
if SERVER then
if CLIENT then
    function (ply)
    end)
Nope, still
  1. [ERROR] addons/ulx/lua/ulx/modules/sh/bdg.lua:16: bad argument #4 to ULib.cmds.TranslateCommand (nil,boolean expected, got string)
  2.   1. error - [C]:-1
  3.    2. checkArg - addons/ulib/lua/ulib/shared/misc.lua:520
  4.     3. instantiate - addons/ulib/lua/ulib/shared/commands.lua:1083
  5.      4. ulxCommand - addons/ulib/lua/ulib/shared/misc.lua:843
  6.       5. command - addons/ulx/lua/ulx/sh_base.lua:43
  7.        6. unknown - addons/ulx/lua/ulx/modules/sh/bdg.lua:16
  8.         7. include - [C]:-1
  9.          8. unknown - addons/ulx/lua/ulx/cl_init.lua:17
  10.           9. include - [C]:-1
  11.            10. unknown - addons/ulx/lua/ulib/modules/ulx_init.lua:4
  12.             11. include - [C]:-1
  13.              12. unknown - addons/ulib/lua/ulib/cl_init.lua:23
  14.               13. include - [C]:-1
  15.                14. unknown - addons/ulib/lua/autorun/ulib_init.lua:5
  16.
    • TrueKnife TTT
« Reply #9 on: April 12, 2015, 10:53:46 am »
NVM. Fixed it though it is not for everyone unless I didnt check my code again
« Reply #10 on: April 12, 2015, 10:06:48 pm »
-snip-
Just so you're aware, that does nothing to the code.  It will still run the same.
And it appears you fixed the code, but if you didn't, the last argument in your ulx.command line is invalid.  That needs to be a boolean for hiding chat.
