Author Topic: Tab menu  (Read 13853 times)
Re: Tab menu
« Reply #15 on: April 13, 2015, 12:13:31 pm »
Something a little easier to both understand and do...
You can use surface.CreateFont to create two fonts.  One normal one and one with some blur.  Draw the text with the blur underneath and the one without the blur on top.
(UNTESTED, but it should work)
  1. surface.CreateFont("MyFont", {size=24, blursize=0})
  2. surface.CreateFont("MyFont_Blurred", {size=24, blursize=0.3})
  3.
  4. function SomeDrawFunction()
  5.         surface.SetFontColor(0, 0, 255, 255)
  6.
  7.         surface.SetFont("MyFont_Blurred")
  8.         local w, h = surface.GetTextSize("THIS IS AN EXAMPLE")
  9.         surface.SetPos(ScrW()/2-w/2, ScrH()/2-h/2)
  10.         surface.DrawText("THIS IS AN EXAMPLE")
  11.
  12.         surface.SetFont("MyFont")
  13.         local w, h = surface.GetTextSize("THIS IS AN EXAMPLE")
  14.         surface.SetPos(ScrW()/2-w/2, ScrH()/2-h/2)
  15.         surface.DrawText("THIS IS AN EXAMPLE")
  16. end
  17. hook.Add("HUDPaint", "DrawGlowExample", SomeDrawFunction)
EDIT:  Sorry, I had my code wrong, fixed it for you.
EDIT2:  Some other functions you'll need...
player.GetAll()
Entity:GetPos()
Vector:ToScreen()
Player:Nick()
Player:GetUserGroup
« Last Edit: April 13, 2015, 12:23:08 pm by Aaron113 »
Offline brycenmm
Re: Tab menu
« Reply #16 on: April 13, 2015, 03:02:40 pm »
  3.
  6.
  11.
  16. end
player.GetAll()
Entity:GetPos()
Vector:ToScreen()
Player:Nick()
Player:GetUserGroup
I'm completely ignorant with lua. Where do I put this stuff?? Where do I put it..?
Offline Livaco
    • Livaco
Re: Tab menu
« Reply #17 on: April 14, 2015, 04:26:08 am »
cl_scoreboard.lua or cl_hud_score.lua
My Website
My Addons
PermaBanV1.0
Livaco Products©
Offline Buzzkill
    • The Hundred Acre Bloodbath
Re: Tab menu
« Reply #18 on: April 14, 2015, 07:48:30 am »
If you're going to copy/paste something I wrote, can you please include the entire context so it doesn't cause confusion?
something like cl_scoreboard.lua, cl_hud_score.lua, etc.. depending on your gamemode
Offline Livaco
    • Livaco
Re: Tab menu
« Reply #19 on: April 14, 2015, 10:26:48 am »
What he asked where it goes
My Website
My Addons
PermaBanV1.0
Livaco Products©
Offline Buzzkill
Re: Tab menu
« Reply #20 on: April 14, 2015, 10:54:09 am »
Do you know exactly which gamemode he's playing?  Or which menu system he is using?  If you direct him to specific files that don't exist, it creates the opportunity for all sorts of confusion that could be avoided by speaking in general terms (which is what I tried to do when I first referenced those two file names).
