Author Topic: Help with ulx  (Read 3924 times)
Offline BeastyIan
Help with ulx
« on: April 19, 2015, 12:33:39 pm »
I need a way to run the command "ulx addxp server 100" every 2 minutes. Anybody know a way I could do it? (Server is the part where you put the player there but I want the whole server to receive the xp every 2 minutes.)
Re: Help with ulx
« Reply #1 on: April 19, 2015, 02:56:45 pm »
http://wiki.garrysmod.com/page/timer/Simple
http://wiki.garrysmod.com/page/Global/RunConsoleCommand
As for targeting everyone, there's always the * target, which targets every available target that its caller has permission to target.
Re: Help with ulx
« Reply #2 on: April 19, 2015, 03:02:08 pm »
If you're trying to write a script to give all players xp every 2 minutes, you should use whatever function the addxp command uses to give the xp rather than forcing the server to run a console command.
Sure, both ways might work, but the former is better practice.
