Suggestions
Usweps
Topic: Usweps (Read 6868 times)
twisted-scot
Usweps
May 06, 2007, 10:15:57 am »
It would be good if someone could make the script for the old ULX Uswep where you can set sweps access levels to certain levels. For example only superadmins can use the nuke and admins can't or operators can use c4 but normal players can't.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Re: Usweps
May 06, 2007, 12:12:59 pm »
If you look in each swep's lua file, there is a 'adminonly' variable at the top I think.
Garry included this by default.
Sorry, I don't know exactly where the files are, and don't have time at the moment to look.
twisted-scot
Re: Usweps
Reply #2 on:
May 06, 2007, 01:41:04 pm »
No what I meant is you could group sweps up like superadmin only sweps.
spbogie
Ulysses Team Member
Sr. Member
Re: Usweps
Reply #3 on:
May 06, 2007, 04:02:52 pm »
SWEPs are handled quite differently in GM10. I haven't looked into it much, but I'm not sure how much can be done to change the way they are handled.
Suggestions
Usweps
