Author Topic: ulx.fancyLogAdmin help  (Read 4915 times)
Offline Baron Von Haxor
« on: May 04, 2015, 03:56:02 am »
Is it possible to give different conditions for a different ulx.fancyLogAdmin being printed. For instance, if a panel is valid, could you change what is printed by ulx.fancyLogAdmin? Thanks :)
Re: ulx.fancyLogAdmin help
« Reply #1 on: May 04, 2015, 08:37:01 am »
Not by default- you'll likely have to modify ulx.fancyLogAdmin yourself.
« Reply #2 on: May 04, 2015, 10:22:16 am »
I'll probably just remake it using chatprint and the variables which should hopefully work.
