Author Topic: ulx timeout  (Read 17192 times)
Offline XxLMM13xX
  • New to lua development
    • Twitch
ulx timeout
« on: May 06, 2015, 03:02:06 pm »
ULX TIMEOUT
This is a simple addon to ULX that will teleport a naughty player to a set location (should be a corner) and freezes them there so they get to think about what they have done!
Commands:
!timeout <player> <seconds for timeout>
Soon to add:
HUD saying "YOU ARE IN TIMEOUT"
!settimeoutspot command
!untimeout command
NEW VIDEO
« Last Edit: May 06, 2015, 04:29:31 pm by XxLMM13xX »
Re: ulx timeout
« Reply #1 on: May 06, 2015, 03:13:10 pm »
Some criticism for ya
1.  the function ulx.freeze I do not believe you need?
2.  You better check to make sure the player hasn't disconnected.  (ply and ply:IsValid() in timer)
3.  Possibly make the position save?  Might just make the addon overly complicated.
4.  A max timeout of 100 seconds is kind of small, increase it or have no limit?
5.  Is calling ulx unfreeze necessary?
Offline XxLMM13xX
    • Twitch
Re: ulx timeout
« Reply #2 on: May 06, 2015, 03:58:08 pm »
1. Looking back... no i will fix this
2. Good point
3. What do you mean?
4. Did not look at that! Will fix
5. Because of #1.... Yes
Re: ulx timeout
« Reply #3 on: May 06, 2015, 04:31:03 pm »
I just meant a way to save position over map changes and such.  It just seems like setting it every time would be annoying.
Offline XxLMM13xX
    • Twitch
Re: ulx timeout
« Reply #4 on: May 06, 2015, 04:32:37 pm »
UPDATE:
Added a !untimeout
Took out the unfreeze command thingy
took out the freeze command
Offline XxLMM13xX
    • Twitch
Re: ulx timeout
« Reply #5 on: May 06, 2015, 04:35:27 pm »
so like a !settimeoutlocation command (not that long)
Ill look into it if so
Offline BobTheDuck
Re: ulx timeout
« Reply #6 on: February 18, 2016, 04:43:01 pm »
This is revolutionary! xD
Offline XxLMM13xX
    • Twitch
Re: ulx timeout
« Reply #7 on: February 20, 2016, 01:55:18 pm »
<3
