Author Topic: Automatic Map Cycle  (Read 6042 times)
Offline FASGamer
Automatic Map Cycle
« on: May 16, 2015, 05:23:00 pm »
So I have a suggestion/request, I think it would be nice to have a Automatic Map Cycle NOT Map Vote. So what this would do is you can set a certain time and after that time it would change to that map.. So lets say my main map is GM_Bigcity, I can set for it every 3 hours to cycle between that map and freespace_06_v2_1.
I found an old addon for ULX which did this from what I can see. I have not tested this addon to see if it works though. And the addon is located here /index.php/topic,688.0.html
So anyways is it possible that someone might can create this for me? Or well this can just act as a suggestion for ULX.
Offline Tomzen
  • A new lua adventurer
    • Thirdage Gaming
Re: Automatic Map Cycle
« Reply #1 on: May 17, 2015, 01:30:21 am »
As far as I see, that plugin should fully work still.
Finished:
Impersonate
WIP:
ServerMode <==
Offline FASGamer
« Reply #2 on: May 17, 2015, 07:59:08 am »
I just tested it and it seems to not work.
