Author Topic: UccTV -- Watch all your players at once -- The ultimate server surveillance!  (Read 89649 times)
A "fixed version" is currently in testing by the forum moderators. Be patient.
How can i get the fixed version?
Register on this forum, then you'll be able to see member file attachments, like the fix pcwizdan did.
Offline atomicspark
Release the fixed version already. :P
Offline iBurnPuppies
I agree, release it!  :)
Offline EggNoggin
The control panel doesnt get created, and i get this:
includes/modules/controlpanel.lua:27: controlpanel.Get() - Error creating a ControlPanel!
You're calling this function too early! Call it in a hook!
It's difficult to keep all our releases working when garry's intent on breaking them as often as possible. :)
Offline EggNoggin
Ah, thanks.  ;D
Offline Wayne Brady
You should be able to click on one player's screen and then it would zoom in 100%, and then press some kind of back button to go back to the list. I mean, on a 42 slot server, it would be impossible to see everything well.
Offline killforfun
It be cool if you added a freeze button to each window so if you catch them spamming you can stop them and then you can go ahead and ban or kick him/her
Woah. Way to wake a topic over 2 years old. (Then again, Megiddo DID mention several old releases in his release post at FP that I'm not even sure work anymore)
Now that is been woken.... anyone tested this or PCWizDan's (mentioned about 3 posts ago) latest 3 year old code to test if it works?
I'd be surprised if it does.
If it does, heck, Stick, add the functionality suggestion in the previous post. Make it a addon tab in XGUI :D
It's on the TODO, me and Megiddo talked about it shortly before we released :P I believe it should be fairly easy to implement, too!
Offline krooks
  • I don't like video games.
    • Diamond Krooks
mm I don't think it does, I've never had any kind of player viewer thing work for me
My TTT server. Join the fun!
Megiddo said it should be working fine, might be the old interface that's broken, yet I haven't confirmed it yet. :P
Offline krooks
    • Diamond Krooks
it actually works fine. I think my problem int he past had to do with the server bug you found of an invalid ban, stickly.
