Author Topic: [TTT] Scoreboard Ranks for ULX - Version 1.2.0  (Read 189963 times)
Offline C.Finley
Re: [TTT] Scoreboard Ranks for ULX - Version 1.1.1
« Reply #30 on: June 26, 2016, 10:46:06 am »
Can you do a name color ulx command and so on plz <3
« Reply #31 on: June 26, 2016, 10:49:39 am »
Commands:
The commands will be listed in the following format: "command" <parameters> -- Command description/explanation
The console commands have a "ulx " prefix, such as: "ulx command".
The chat commands have a "!" prefix, such as: "!command".
The commands will be listed by permissions. This is just by default and can be edited via ULX/XGUI as any other commands.
  • Admins:
    • "addrank" <player> <rank> <red> <green> <blue> -- Adds or changes rank for a player, with custom colors using RGB[/i]
    • "addrankid" <steam_id> <rank> <red> <green> <blue> -- Adds or changes rank of a Steam ID, with custom colors using RGB[/i]
    • "changerank" <player> <rank> <red> <green> <blue> -- See "addrank" - Only works for existing custom ranks.
    • "changerankid" <steam_id> <rank> <red> <green> <blue> -- See "addrankid" - Only works for existing custom ranks.
    • "removerank" <player> -- Removes someone's custom rank if it exists.
    • "removerankid" <steam_id> -- Removes someone's custom rank (using their Steam ID) if it exists.
    • "rainbowrank" <player> <rank> -- Adds/changes rank of a player and sets the color to cycle ("rainbow").
    • "rainbowrankid" <steam_id> <rank> -- Adds/changes rank of a Steam ID and sets the color to cycle ("rainbow").
  • Superadmins:
    • "addgrouprank" <group name> <rank> <red> <green> <blue> -- Adds or changes rank for a group, with custom colors using RGB
    • "removegrouprank" <group name> -- Removes a custom group rank.
    • "rainbowgrouprank" <group name> <rank> -- Adds/changes rank of a group and sets the color to cycle ("rainbow").
    • "columnname" <column name/title> -- Changes the column name/title that is displayed at the top of the scoreboard.
    • "defaultrank" <rank> -- Changes the default rank for players and groups that have no custom rank. This rank is RGB: 255, 255, 255 (white).
    • "columnwidth" <width> -- Changes the column width in the scoreboard.
Unless you mean in chat, in which case that would be a separate addon.
« Last Edit: June 26, 2016, 10:51:35 am by Bytewave »
Offline C.Finley
« Reply #32 on: June 26, 2016, 10:51:02 am »
No he only does rank colors i mean add a name color one your rank is basically color = Color(....) while name = color( one for rank one for name like easy scoreboard cause i know you took the rgb setup from there so example EZS.Ranks["sadmin"] = { name = "Super Admin", color = Color( 255, 0, 255 ), namecolor = "rainbow", admin = true }
« Last Edit: June 26, 2016, 10:52:43 am by C.Finley »
« Reply #33 on: June 26, 2016, 10:52:22 am »
Ooooh, wait, I misread that.
Decicius is online... *poke*?
« Reply #34 on: June 26, 2016, 11:00:35 am »
Sadly, my interest in this addon isn't as what it used to be, so I will have to say no to that (at least in the foreseeable future). Sorry.
As I've mentioned before, the addon is open-source and listed on GitHub - If anyone wishes to modify it for one reason or another, the license allows them to.
« Reply #35 on: June 26, 2016, 11:03:08 am »
Would you still accept pull requests, or should the repo be forked and re-released?
« Reply #36 on: June 26, 2016, 11:03:39 am »
Pull requests will be accepted, after I've been able to look over them.
EDIT: Rephrasing.
« Last Edit: June 26, 2016, 11:05:48 am by Decicus »
Offline C.Finley
« Reply #37 on: June 26, 2016, 11:26:50 am »
Offline dimdu54
« Reply #38 on: July 22, 2016, 09:53:58 am »
Thx for this mate really needed this :D
Offline ozzyos2009
« Reply #39 on: November 30, 2016, 08:32:25 pm »
Firstly, I apologize for replying to this as it's 5 months since the last reply. I also apologize as I'm new and learning lua.
This is in regards to a colored name on the scoreboard. I had an old script that worked, I just had to put this in AddCSLuaFile("tg_ttt_scoreboard.lua")
Now I noticed under lua/autorun/client/cl_tttsbrank.lua you created  a new scoreboard. Would I simply change tg_ttt_scoreboard.lua to cl_ttsbranks.lua? Or is it more complex than that?
« Reply #40 on: December 02, 2016, 01:23:41 pm »
Unless it's based off my cl_tttsbranks.lua file, then it won't work like that. You would have to modify the addon to support colored names, which I never got around to adding and as I mentioned; I sadly don't have any interest in working on this addon anymore. Sorry.
Offline wolwos40u
« Reply #41 on: May 19, 2017, 03:21:19 pm »
I deleted and reinstalled addon now every rank are disappeared in scoreboard and addon seems not installed. (commands are not working and there's nothing on ULX menu)
« Reply #42 on: May 21, 2017, 02:51:19 pm »
That seems like the addon hasn't loaded at all, so maybe you didn't install it correctly?
You could try changing the name of the folder inside "addons" to all-lowercase (something like ttt_sb_ranks instead of TTT-Scoreboard-Ranks-for-ULX-1.1.1), as I believe that is an issue on some servers.
Offline ryanogamer
« Reply #43 on: May 27, 2017, 05:25:50 pm »
Thanks for this
Offline wolwos40u
« Reply #44 on: May 30, 2017, 01:49:18 pm »
Worked for me thank you so much.
