Author Topic: Custom MOTD conflicting?  (Read 5390 times)
Offline NexusRadical
« on: May 31, 2015, 01:40:33 am »
Hello all, thanks for any posts, I've been trying to sort this out for about 5 fours straight, i just got my gmod server which i intend to use for darkrp, the game mods running and its on downtown, so its all correctly setup. No matter what i do, i cant get any custom MOTD menus to active. i really want ModernMOTD which I've paid for to work, but despite doing what the instructions say, it not working, i extra ModernMOTD folder which contains all of the content to the addons folder but it doesn't work, I've disable the ulx motd, but whenever i type !motd to use ModernMOTD, it says motd is disable on this server... That do i do to fix this, nothing I've tried is working...
Well it loads in the console...
Adding Filesystem Addon '/home/tcagame/callumc/83/garrysmod/addons/modernmotd'
Adding Filesystem Addon '/home/tcagame/callumc/83/garrysmod/addons/awarn2'
Adding Filesystem Addon '/home/tcagame/callumc/83/garrysmod/addons/darkrpmodification-master'
Adding Filesystem Addon '/home/tcagame/callumc/83/garrysmod/addons/ulib'
Adding Filesystem Addon '/home/tcagame/callumc/83/garrysmod/addons/ulx'
« Last Edit: May 31, 2015, 01:44:04 am by NexusRadical »
Offline Caustic Soda-Senpai
    • Steam Page
Re: Custom MOTD conflicting?
« Reply #1 on: May 31, 2015, 07:17:01 am »
rename the characters in your folder to ALL lowercase; you're most likely using a Linux system that isn't picking up the capitals.
Offline Senpai Nick
« Reply #2 on: June 18, 2015, 12:06:21 am »
I'm having some what of the same issue. My paid motd isn't conflicting, but both my paid motd and ulx motd are showing up. How do i disable ulx motd
    • Steam Page
« Reply #3 on: June 18, 2015, 09:33:33 am »
You can disable it from the Settings in the XGUI Menu.
« Reply #4 on: June 23, 2015, 06:59:49 pm »
You probably should modify or remove ulx\lua\ulx\modules\cl\motdmenu.lua to prevent the ULX Motd and/or the "The motd is disabled on this server!" message to disappear.
