Author Topic: Get MOTD from url.  (Read 4937 times)
Offline Crew Froebel
Get MOTD from url.
« on: June 29, 2015, 02:32:20 pm »
MOTD settings. Get MOTD from url is greyed out. :o
Please help me. Explain best you can because I'm new. But still experienced enough to figure this out.
Re: Get MOTD from url.
« Reply #1 on: June 30, 2015, 11:43:05 am »
It's very likely a bug- people have been reporting issues with MOTD settings in XGUI as of late- I just haven't had time to take a look at them yet.
For now, you can set the MOTD URL via console, like so:
ulx showMotd http://www.google.com/
.. OR if you're feeling adventurous, you can modify your server's garrysmod/data/ulx/config.txt and set the URL there.
Offline Mistress Kerrigan?
« Reply #2 on: June 30, 2015, 03:15:51 pm »
Tried both, both failed.
Enabled Motd to open upon join, resets.
Outcome: http://i.gyazo.com/389f2da1b4d81da5f687910bbfd1582b.png
Set showMotd to url in console:
Set showMotd to url:
Outcome: http://steamcommunity.com/sharedfiles/filedetails/?id=472722225
Offline Atrei
« Reply #3 on: July 27, 2015, 05:26:48 pm »
I'm having this issue on my server, as well. The code hasn't been edited in quite a while and worked previously, however the MOTD now shows up as a blank grey box identical to the one in the screenshot that Kerrigan provided.
I registered on these forums hoping to find a solution, but this is the first mention of the issue that I've found and it's gone unaddressed.
Has any progress been made?
« Reply #4 on: July 31, 2015, 03:03:30 pm »
Took me a while to get around to it- but I finally pushed a fix for this! Sorry about that.
