Author Topic: [ULX] Countdown ~ quick and easy countdowns  (Read 10790 times)
Offline Tomzen
  • A new lua adventurer
    • Thirdage Gaming
« on: June 30, 2015, 01:55:52 am »
Description:
Easily start a countdown by typing "!countdown <seconds>", if the seconds are more then 5, there will also be a countdown from 5 seconds as well:
Otherwise it will appear as:
NOTE: It will say the time you started the countdown for (not 10 or 4)
Requirements:
This version requires ULX and ULIB
Installation:
Download == Extract the zip and put the content into the specified files, restart map, server or client. done.
TO DO:
  • Make not require ulx or ulib.
  • Create a stopwatch to go with.
« Last Edit: June 30, 2015, 01:57:36 am by Tomzen »
Finished:
Impersonate
WIP:
ServerMode <==
Re: [ULX] Countdown ~ quick and easy countdowns
« Reply #1 on: June 30, 2015, 10:15:18 am »
You should add the ability to automatically execute a command at the end of a timer.  Might also be wise to add more than a 5 second warning for long timers (like 30 minute timers).  Like server restarting in 30 minutes, it will give them a better warning so they can save stuff.  I always found these things useful when I had something similar in my OLD OLD sandbox server.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #2 on: July 01, 2015, 01:48:01 pm »
Personally, I wouldn't change this addon to from ulx to non-ulx, that's just my two cents. Also, is this considered smart time, as in it will convert seconds to minutes if x > 59 (i.e. 1:02)?
