If I remember right, the easiest and 'only' way is to modify
lines 626-630 in cl_voice.lua of the gamemode. This isn't recommended, as it will probably need to be modified again after a Garry's Mod update, but I don't think there's currently any other way.
Should look something like:
if ply:IsAdmin() or ply:IsDetective() then
return GetGlobalFloat("ttt_voice_drain_admin", 0) -- Default 0.05
elseif ply:IsUserGroup( "vip" ) then
return 0.1
return GetGlobalFloat("ttt_voice_drain_normal", 0) -- Default: 0.2
0.1 is just an example, since it's half of the drain rate of normal players, thus giving twice the battery for "vip". Change this how you would like it to be.
