Author Topic: Possible ULX Issue  (Read 3992 times)
Offline Doctor Jew
Possible ULX Issue
« on: July 15, 2015, 09:28:20 pm »
So over the past month, one of my servers has gone through immense troubleshooting. Client crashes were the main cause. We have tested many things, even moving over to another server box. However, one thing that has remained constant was that we transferred over all ULX/Ulib data.
Is it possible corrupt data can be causing client/server crashes?
Thanks for any input.
Re: Possible ULX Issue
« Reply #1 on: July 16, 2015, 07:09:19 pm »
Unless you're running Sandbox, another 'constant' would be your gamemode. Which I'm going to assume is DarkRP (only because I'm a betting man).
Poor client code in any aspect could cause Client crashing. Do you have any more info about the crashing? Is it CTD or Main Menu?
While I can't rule out ULX/ULib, we don't get many complaints of it causing crashing.
Offline Doctor Jew
« Reply #2 on: July 17, 2015, 12:01:58 am »
It's a CTD. It started happening about a month ago, and looking back nothing was even added at that time. Possibly an addon updated and something conflicts? Kinda just started happening.
Also yes, it is DarkRP. Good guess. I will go ahead and try a full data reset however. I've also been told by players crashes seem to get worse later in the night? Not really sure if that's true, could just feel like it does.
EDIT: Deleted all ULX/ULib data. Didn't fix anything, guess it wasn't the issue.
« Last Edit: July 17, 2015, 01:19:31 am by Doctor Jew »
« Reply #3 on: July 17, 2015, 08:18:42 am »
No, ULX wouldn't cause a CTD. I'm not really sure what would cause a CTD in GarrysMod. Possibly an asset (model/material/sound) that is corrupt.
I suggest you try removing ALL of your addons except ULX and your gamemode and see if that fixes it. Then start adding them back in one or two at a time until you find what is causing the problem.
