I'm concerned as to why it is breaking. When I press Settings you know how you normally get the little toggles with Props, SENTs, Ragdolls etc? That's not there. Completely blank. I've been trying to get URS to restrict props to a certain amount but it won't do it in the little menu tab. There's no list. Just blank when I click restrictions. I try to do it through the little dropdown menu on ULX. I get this
[ERROR] addons/ulx/lua/ulx/modules/cl/xgui_helpers.lua:302: attempt to perform arithmetic on local 'maxvalue' (a nil value)
1. x_getcontrol - addons/ulx/lua/ulx/modules/cl/xgui_helpers.lua:302
2. obj - addons/ulx/lua/ulx/xgui/commands.lua:210
3. func - addons/ulx/lua/ulx/modules/cl/xlib.lua:1098
4. animQueue_call - addons/ulx/lua/ulx/modules/cl/xlib.lua:1079
5. func - addons/ulx/lua/ulx/modules/cl/xlib.lua:1098
6. animQueue_call - addons/ulx/lua/ulx/modules/cl/xlib.lua:1079
7. func - addons/ulx/lua/ulx/modules/cl/xlib.lua:1098
8. animQueue_call - addons/ulx/lua/ulx/modules/cl/xlib.lua:1079
9. Stop - addons/ulx/lua/ulx/modules/cl/xlib.lua:1026
10. Run - addons/ulx/lua/ulx/modules/cl/xlib.lua:1033
11. fn - addons/ulx/lua/ulx/modules/cl/xlib.lua:1043
12. Call - addons/ulib/lua/ulib/shared/hook.lua:110
13. unknown - addons/ulx/lua/ulx/modules/cl/xgui_helpers.lua:31
When I reconnect it fixes it, but it seems to happen. I was trying to set a permission and it did it half way through.
:s
Okay this is NOT good! I can't set any permissions, it just removes the selection.
EDIT: A script was breaking ULX. It's been removed and ULX is fine.
