General
Off-Topic
Demote Command
Topic: Demote Command (Read 8291 times)
Rockit14
Demote Command
July 21, 2015, 10:34:21 am »
I think their should be a command which is used for DarkRP. You simply type !demote (Name) and then it will put them back to your default group (Citizen). This would be SOOO helpful on my server.
MrPresident
Ulysses Team Member
Re: Demote Command
July 21, 2015, 10:54:00 am »
So create this or have someone create this for you.
We do not cater to specific gamemodes inside of the official ULX/ULib releases.
I'm moving this to Off-Topic. Maybe someone will see it and post some help.
Tomzen
Full Member
A new lua adventurer
Re: Demote Command
Reply #2 on:
July 25, 2015, 02:42:12 am »
A bit late, but here you go:
/index.php/topic,8818.0.html
< Post with download/instructions and usage.
SOURCE:
-- Config Section
CATEGORY_NAME
"DarkRP"
-- the category it appears in
JOB_NAME
"Citizen"
-- default job name
CMD_NAME
"citizen"
-- cmd to run (e.g ulx citizen, !citizen) Don't add the exclamation mark or "ulx"
HELP_LINE
"Demote a player of choice!"
-- default help message
-- Config END
-- Dont edit below this line
function
ulx
forcedemote
calling_ply
target_ply
game
ConsoleCommand
"rp_citizen "
target_ply
Nick
\n
-- Sends the command to console to run
ulx
fancyLogAdmin
calling_ply
true
"#A forced #T's job to "
JOB_NAME
target_ply
ULib
csay
target_ply
"Your job was forced to "
JOB_NAME
" by an admin."
local
forcedemote
ulx
command
CATEGORY_NAME
"ulx "
CMD_NAME
ulx
forcedemote
CMD_NAME
true
forcedemote
addParam
type
ULib
cmds
PlayerArg
forcedemote
defaultAccess
ULib
ACCESS_ADMIN
forcedemote
help
HELP_LINE
-- End
Finished:
Impersonate
FakePromote/Demote
RandomMap
ForceMic
Search
PlayMenu
WIP:
ServerMode
General
Off-Topic
Demote Command
