Author Topic: Admin Problems  (Read 3603 times)
Offline Dew Man
Admin Problems
« on: July 26, 2015, 10:41:06 pm »
I am having so much trouble with powers
I am a super admin, i have added my self to the users file and given my self all the powers i can, but i still cannot use the tools in the utilities tab, nor can i use addons such as falco's prop protection or simple prop protection, i don"t know where else to post this so if it is in the wrong place, don't scream at me, direct me in the right place, thanks for all the help in advanced.
« Last Edit: July 27, 2015, 07:28:49 pm by JamminR »
Re: Admin Problems
« Reply #1 on: July 27, 2015, 07:32:42 pm »
If you are superadmin - that exact name, case sensitive (all lower case), and added yourself as described in either
/index.php/topic,3068.0.html
or /index.php/topic,5766.0.html
or the troubleshooting FAQ
" /index.php/topic,383.0.html "
you do NOT need to 'add all the powers' in ULX, superadmin already has them.
Oh, and if your NOT using superadmin, because your using another gamemode that says you should be 'owner', then it's also likely using an incompatible admin mod.
