Author Topic: Spectator mode for Excl's Jailbreak 7  (Read 13685 times)
Offline Janjakob2000
« on: August 02, 2015, 05:34:01 am »
Welcome to my first ULib addon!
What does it do?
You can forcefully put people in spectator mode, for if they are AFK, instead of kicking them.
Requirements:
-Latest release of ULib and ULX
-Excl's Jailbreak 7 gamemode
Bugs
Haven't found any yet.
What are the commands for it?
There's 2 chat commands:
!forcespec <playername>
!spec <playername>
And 1 console command:
ulx forcespec <playername>
FAQ
Q: Why does this not work on my server?
A: You're probably using a different gamemode, this only works for Excl's Jailbreak 7 gamemode for now.
Q: Will you be doing support for other gamemodes?
A: Yes of course I will!
Q: Can I help you supporting other gamemodes?
A: Sure thing, just PM me your steam and I'll add you!
To-Do List
-If enough people want it, I'll try and make it check if the player is in spectator mode and disable the points given over time if you have pointshop installed.
If you want me to support more gamemodes, you can always suggest it to me, and I'll add it to the To-Do List.
You must be logged in to see the download link!
« Last Edit: August 03, 2015, 03:03:13 am by Janjakob2000 »
Re: Spectator mode for Excl's Jailbreak 7
« Reply #1 on: August 02, 2015, 06:57:16 am »
Does Gmod load legacy addons without an addon.txt now?
(You do not have one in your path)
Additionally -
I suggesting telling what command(s)/how to use it in your first post.
To make it more *nix friendly, don't use a space in the folder name (ie, force_spectator)
« Reply #2 on: August 03, 2015, 02:58:34 am »
Additionally -
Thanks JamminR!
I've fixed it, shouldn't be too hard.
Offline [aBoom] Erik @Membersuche
« Reply #3 on: August 03, 2015, 03:57:01 am »
Ähm you know u can make people simply spectator by right click on the Scoreboard ?
« Reply #4 on: August 03, 2015, 08:21:06 am »
That doesn't work when ever I try to do it on someone.
