Author Topic: ulx no commands issue  (Read 4128 times)
Offline oneshotonekillnoluckjustskill
« on: August 04, 2015, 11:01:02 am »
Ive started a server recently and instaled ulx but when i did !menu all that came up was usermanagment help no other commands came up ive tried reinstalling ulx but nothing works                  here is a picture                         http://steamcommunity.com/profiles/76561198034179041/screenshot/443954789240565956
« Last Edit: August 07, 2015, 03:01:35 pm by MrPresident »
Re: ulx no commands issue
« Reply #1 on: August 04, 2015, 11:24:09 am »
I hear FAdmin is bad.  It's built into DarkRP, might want to try to disable it.  Otherwise a fresh install of ULX/ULib might be good (make sure it's from this website).  And factory reset might be wise if disabling FAdmin doesn't work.  You can find instructions in the FAQ section.
« Reply #2 on: August 04, 2015, 07:17:55 pm »
i tried that and it didnt work
Offline Ryan Hemmet
    • https://adversarygaming.com
« Reply #3 on: August 05, 2015, 06:46:28 pm »
User management help is by default given to users, are you sure you are set to superadmin in ULX?
(Console commands: ulx adduser [name] [group] OR ulx adduserid [steamid] [group])
« Reply #4 on: August 07, 2015, 02:27:14 am »
thank you so much it works
Offline Ryan Hemmet
« Reply #5 on: August 07, 2015, 09:01:12 am »
Glad to help  ;D
