Author Topic: Revoke Access to Default Commands?  (Read 4518 times)
Offline Officially
« on: August 05, 2015, 08:18:37 am »
Hi, I'm testing out ULX on a testing server I've made. I've added the 'Custom Commands' addon for it because it adds some great commands, however I want to revoke access to !votegag from a rank, but cannot seem to revoke access to a default command despite being a superadmin  :(
Any help is appreciated  :)
Offline Ryan Hemmet
    • https://adversarygaming.com
Re: Revoke Access to Default Commands?
« Reply #1 on: August 05, 2015, 06:41:59 pm »
Are you trying to revoke access from a rank that is inheriting from a rank that has access to the command? or are you trying to revoke the command from the 'user' rank?
Offline Officially
« Reply #2 on: August 08, 2015, 10:51:17 am »
I'm trying to remove the commands from a non-user group which did, by default, have them. The tick box is slightly greyed and I cannot remove the tick.
« Reply #3 on: August 10, 2015, 08:32:34 am »
This likely means that the permission is being inherited from a lower group. You should be able to right-click the permission, and it will let you "Revoke access from <whatever> group".
