Author Topic: Console error!  (Read 6798 times)
Offline Aerosoft
Console error!
« on: August 10, 2015, 02:08:42 pm »
I'm having a problem with the ulx auto promote addon where it is spamming an error in my console
ULib queue error: addons/ulx_auto_promote/lua/ulx/xgui/server/sv_apromote.lua:110: attempt to call method 'GetUTimeTotalTime' (a nil value)
Here is the lua code
// APromoteGUI by Lead4u, Modified and Fixed by Mr. Apple    //
// Version: 3.5 Full Release                                 //
resource.AddFile("materials/gui/silkicons/cog.vmt")
ULib.ucl.registerAccess( "apromote_settings", "superadmin", "Allows managing all settings related to APromote.", "XGUI" )
local APromote = {}
local set = {} APromote["set"] = set
local grp = {} APromote["grp"] = grp
util.AddNetworkString( "doApShinys" )
local function Save()
file.Write( "ulx/apromote.txt", ULib.makeKeyValues( APromote ) )
local function APUpdateGroups()
//for added groups
for k, v in pairs(ULib.ucl.groups) do
if ( APromote["grp"][k] == nil and k != "user") then
print("Added " .. k .. " to APromote.")
APromote["grp"][k] = -1
for k, v in pairs(APromote["grp"]) do
if ( k != nil and !ULib.ucl.groups[k]) or k == "user" then
print("Removed " .. k .. " from APromote.")
APromote["grp"][k] = nil
xgui.sendDataTable( {}, "AP_SendData" )
Save()
local function loadAP()
xgui.addDataType( "AP_SendData", function() return APromote["grp"] end, "apromote_settings", 0, 0 )
// File Stuffs
if not file.Exists( "ulx/apromote.txt", "DATA" ) then
APromote["set"]["ap_enabled"] = 1
APromote["set"]["ap_snd_enabled"] = 1
APromote["set"]["ap_snd_scope"] = 1
APromote["set"]["ap_effect_enabled"] = 1
APromote["set"]["ap_auto_demote"] = 0
Save()
APromote = ULib.parseKeyValues( file.Read( "ulx/apromote.txt" ) )
// ConVars
ULib.replicatedWritableCvar("ap_enabled","rep_ap_enabled", APromote["set"]["ap_enabled"],false,false,"apromote_settings")
ULib.replicatedWritableCvar("ap_snd_enabled","rep_ap_snd_enabled",APromote["set"]["ap_snd_enabled"] ,false,false,"apromote_settings")
ULib.replicatedWritableCvar("ap_snd_scope","rep_ap_snd_scope",APromote["set"]["ap_snd_scope"] ,false,false,"apromote_settings")
ULib.replicatedWritableCvar("ap_effect_enabled","rep_ap_effect_enabled",APromote["set"]["ap_effect_enabled"] ,false,false,"apromote_settings")
ULib.replicatedWritableCvar("ap_auto_demote","rep_ap_auto_demote",APromote["set"]["ap_auto_demote"] ,false,false,"apromote_settings")
// Data and Hook Add
hook.Add( "UCLChanged", "doApUpdateSV", APUpdateGroups )
local function cVarChange( sv_cvar, cl_cvar, ply, old_val, new_val )
if ( sv_cvar =="ap_enabled" or sv_cvar=="ap_snd_enabled" or sv_cvar=="ap_snd_scope" or sv_cvar=="ap_effect_enabled" or sv_cvar=="ap_auto_demote" ) then
APromote["set"][sv_cvar] = new_val
Save()
local function PlayRankSound( ply )
if ( GetConVarNumber( "ap_effect_enabled" ) == 1 ) then
net.Start( "doApShinys" )
net.WriteEntity( ply )
net.Broadcast()
if ( GetConVarNumber( "ap_snd_enabled" ) == 1) then
if ( GetConVarNumber( "ap_snd_scope" ) == 1 ) then
for k, v in pairs(player.GetAll()) do
v:SendLua("surface.PlaySound( \"/garrysmod/save_load1.wav\" )")
elseif ( GetConVarNumber( "ap_snd_scope" ) == 0) then
ply:SendLua("surface.PlaySound( \"/garrysmod/save_load1.wav\" )")
local function isValidCommand( command, compare )
for k, v in pairs( compare ) do
if ( command[1] == k ) then
if ( type( command[2] == "number")) then
return true
return false
concommand.Add("APGroup", function( ply, cmd, args )
if (ply:query( "apromote_settings" ) and isValidCommand( args, APromote["grp"] )) then
APromote["grp"][args[1]] = tonumber(args[2])
Save()
end)
local function checkPlayer( ply )
local plyhours = math.floor( ply:GetUTimeTotalTime() / 3600 )
local usrgrp = ply:GetUserGroup()
local Rank = ""
local Hours = 0
for k, v in pairs( APromote["grp"] ) do
if plyhours >= tonumber( v ) and tonumber( v ) >= Hours then
if tonumber( v ) >= 0 then
Rank = k
Hours = tonumber( v )
if (!ply:IsUserGroup(Rank) and Rank != "") then
if tonumber( APromote["grp"][usrgrp]) != -1 then
if not tobool( GetConVarNumber( "ap_auto_demote" ) ) and APromote["grp"][usrgrp] != nil
and Hours < tonumber( APromote["grp"][usrgrp] ) then
return
if ply:IsConnected() then
RunConsoleCommand( "ulx", "adduserid", ply:SteamID(), Rank )
timer.Create("doAPUpdateTimer", 10, 0, function()
if not tobool( GetConVarNumber( "ap_enabled" ) ) then return end
for k, v in pairs( player.GetAll() ) do
if (v:IsPlayer() and v:IsValid() and !v:IsBot()) then
ULib.queueFunctionCall( checkPlayer, v )
end)
xgui.addSVModule( "AP_LoadAP", loadAP )
hook.Add( "ULibReplicatedCvarChanged", "APGroupCVAR", cVarChange )
Re: Console error!
« Reply #1 on: August 10, 2015, 06:32:21 pm »
Likely, you don't have UTime installed, or installed correctly.
Additionally, please ask for help with <addon> in the <addon's release post> instead of the general ULib/ULX help area, as each author may monitor their own releases.
Offline Aerosoft
Re: Console error!
« Reply #2 on: August 10, 2015, 06:35:00 pm »
My apologies! I wasn't aware on where to post this but thank you for the help!
