Author Topic: Pointshop Addon Help  (Read 5550 times)
Offline mrbell11
« on: August 11, 2015, 02:40:23 pm »
A very long Time ago I got this addon that you could use to give points in pointshop for Console (Donator stuff) Today it is bugging my ulx out by making it so every thing is the ulx give points  (EX: I try to ban someone instead of giving me the ban box where I click their name reason of ban and click ban It will give me the ULX pointshop give box)
Here is the code
ulx.pointshop_item_list = {}
for k,v in pairs(PS.Categories) do
table.insert(ulx.pointshop_item_list, "- "..v.Name.." -")
for a,b in pairs(PS.Items) do
if b.Category == v.Name then
table.insert(ulx.pointshop_item_list, a)
function ulx.pointshop_givepoints( calling_ply, target_plys, points )
if !PS then
ULib.tsayError( calling_ply, "Pointshop is not loaded. Cannot give points.", true )
return
for k,v in pairs( target_plys ) do
if points ~= 0 then
v:PS_GivePoints(points)
ulx.fancyLogAdmin( calling_ply, "#A gave #T #s #s", target_plys, points, PS.Config.PointsName )
local pointshop_givepoints = ulx.command( "Pointshop", "ulx givepoints", ulx.pointshop_givepoints, "!givepoints" )
pointshop_givepoints:addParam{ type=ULib.cmds.PlayersArg }
pointshop_givepoints:addParam{ type=ULib.cmds.NumArg, default=1, hint="points", min=1 }
pointshop_givepoints:defaultAccess( ULib.ACCESS_SUPERADMIN )
pointshop_givepoints:help( "Gives the targeted player(s) a number of points to the pointshop." )
function ulx.pointshop_takepoints( calling_ply, target_plys, points )
if !PS then
ULib.tsayError( calling_ply, "Pointshop is not loaded. Cannot take points.", true )
return
if points ~= 0 then
if v:PS_GetPoints() >= points then
v:PS_TakePoints(points)
v:PS_TakePoints(v:PS_GetPoints())
ulx.fancyLogAdmin( calling_ply, "#A took #s #s from #T", points, PS.Config.PointsName, target_plys )
local pointshop_takepoints = ulx.command( "Pointshop", "ulx takepoints", ulx.pointshop_takepoints, "!takepoints" )
pointshop_takepoints:addParam{ type=ULib.cmds.PlayersArg }
pointshop_takepoints:addParam{ type=ULib.cmds.NumArg, default=10, hint="points", min=1 }
pointshop_takepoints:defaultAccess( ULib.ACCESS_SUPERADMIN )
pointshop_takepoints:help( "Takes a number of points from the pointshop of the target player(s)." )
function ulx.pointshop_setpoints( calling_ply, target_plys, points )
if !PS then
ULib.tsayError( calling_ply, "Pointshop is not loaded. Cannot set points.", true )
return
ulx.fancyLogAdmin( calling_ply, "#A set #s #s for #T", points, PS.Config.PointsName, target_plys )
local pointshop_setpoints = ulx.command( "Pointshop", "ulx setpoints", ulx.pointshop_setpoints, "!setpoints" )
pointshop_setpoints:addParam{ type=ULib.cmds.PlayersArg }
pointshop_setpoints:addParam{ type=ULib.cmds.NumArg, default=0, hint="points", min=0 }
pointshop_setpoints:defaultAccess( ULib.ACCESS_SUPERADMIN )
pointshop_setpoints:help( "Sets the target player(s) pointshop points to the specified number." )
function ulx.pointshop_giveitem( calling_ply, target_plys, item )
if !PS then
return
if !PS.Items[item] then
ULib.tsayError( calling_ply, "Cannot give item. Item \""..item.."\" invalid.", true )
return
if v:PS_HasItem(item) then
table.remove(target_plys,k)
ULib.tsayError( calling_ply, v:Name().." already has "..item.."!", true )
v:PS_GiveItem(item)
ulx.fancyLogAdmin( calling_ply, "#A gave a #s to #T", item, target_plys )
local pointshop_giveitem = ulx.command( "Pointshop", "ulx giveitem", ulx.pointshop_giveitem, "!giveitem" )
pointshop_giveitem:addParam{ type=ULib.cmds.PlayersArg }
pointshop_giveitem:addParam{ type=ULib.cmds.StringArg, hint="item", completes=ulx.pointshop_item_list }
pointshop_giveitem:defaultAccess( ULib.ACCESS_SUPERADMIN )
pointshop_giveitem:help( "Gives the target player(s) the specified pointshop item." )
function ulx.pointshop_takeitem( calling_ply, target_plys, item )
if !PS then
return
ULib.tsayError( calling_ply, "Cannot take item. Item \""..item.."\" invalid.", true )
return
if v.PS_Items[item].Equipped then
v.PS_Items[item].Equipped = false
PS.Items[item]:OnHolster(v)
v:PS_TakeItem(item)
ULib.tsayError( calling_ply, v:Name().." does not have "..item.."!", true )
ulx.fancyLogAdmin( calling_ply, "#A took a #s from #T", item, target_plys )
local pointshop_takeitem = ulx.command( "Pointshop", "ulx takeitem", ulx.pointshop_takeitem, "!takeitem" )
pointshop_takeitem:addParam{ type=ULib.cmds.PlayersArg }
pointshop_takeitem:addParam{ type=ULib.cmds.StringArg, hint="item", completes=ulx.pointshop_item_list }
pointshop_takeitem:defaultAccess( ULib.ACCESS_SUPERADMIN )
pointshop_takeitem:help( "Takes away the target player(s) access to the specified pointshop item, forcing them to rebuy it." )
