Author Topic: can't enter server while owner are online :o  (Read 8972 times)
Offline 3RB
« on: August 25, 2015, 01:39:06 am »
i have a serious big problem that when i'm online in my sevrer people who want to join my public server can't join because i'm in the server when i dissconnect they spawn if i'm online he stucks in sending client info for them i see in console says for me player are connected and he spawn but i can't see him in game then he disconnect i need a fix for that pls  :'(
Offline Caustic Soda-Senpai
    • Steam Page
Re: can't enter server while owner are online :o
« Reply #1 on: August 25, 2015, 04:21:47 am »
...............That's not a thing. Sounds kinda like you're localhosting your server and don't have your ports forwarded.
Offline 3RB
« Reply #2 on: August 25, 2015, 04:31:56 am »
No i port forwarded and my server are public and people who want to join cant join while i' m in the server
« Last Edit: August 25, 2015, 04:33:40 am by 3RB »
    • Steam Page
« Reply #3 on: August 25, 2015, 04:35:28 am »
Yet again, that's not a thing.
Then it's most likely a resource problem. Meaning your internet can't handle a client AND you in the server at the same time.
Two solutions.
1) Get better internet.
2) Rent a Dedicated Host.
Offline 3RB
« Reply #4 on: August 25, 2015, 06:20:39 am »
every solution are worst than than other :'(
« Reply #5 on: August 25, 2015, 12:50:09 pm »
Are you trying to host a server from your computer?
What are the specs of your computer?
CPU, RAM, etc.
Also, go to http://www.speedtest.net and run that test. Post the results here please.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #6 on: August 26, 2015, 04:05:37 am »
If you are portforwarding, and this is a dedicated server on the same computer that you're trying to play garry's mod, make sure your port is not on 27015 for your server, change it to 27016 or 27014 and then try again, as this should fix the issue.
Offline 3RB
« Reply #7 on: August 26, 2015, 12:36:29 pm »
Why it most not be 27015 actually i' m using 27015 i will try the other ports tomorrow i hope you guys answer me soon not like this late reply ;D  :P
« Last Edit: August 26, 2015, 12:38:27 pm by 3RB »
« Reply #8 on: August 26, 2015, 07:49:28 pm »
I believe it has something to do with your client and server trying to use the same port.
« Reply #9 on: August 27, 2015, 12:35:27 am »
Ye, something like that. I forgot specially what the issue was, but I discovered it back in '69 2011 garry's mod days..
Offline 3RB
« Reply #10 on: August 27, 2015, 03:26:11 am »
i tryed to change port to 2016 and 2014 but it be's puplic only in 27015 i think theres a file in server files i must edit it and change 2015 to 2014,2016
« Last Edit: August 27, 2015, 03:29:31 am by 3RB »
Offline 3RB
« Reply #11 on: August 27, 2015, 02:34:28 pm »
Actually i found that they enter after long time because of addons and they were exiting while loading
Simply i'm idiot NVM
Btw thanks for the soppurt guys
« Last Edit: August 27, 2015, 02:40:15 pm by 3RB »
« Reply #12 on: August 27, 2015, 05:14:18 pm »
So I guess this can be archived then.
