Author Topic: Falco Prop Protection being broken by ULX  (Read 7899 times)
Offline unown294
« on: August 28, 2015, 07:25:32 pm »
Hi i am running a Garry's mod build and kill server that has ULX as admin tools and then Falco Prop Protection for the self explanatory job. But recently i ran into an issue that when you hit the admin button on FPP setting it automatically crashes the game. I know its ULX as when i removed every file tested still didn't work remove ULX file it finally worked. but with ULX remove i cant edit anything on FPP.
Re: Falco Prop Protection being broken by ULX
« Reply #1 on: August 28, 2015, 08:24:58 pm »
Provide the full lua error that appears in the server console before server crashes.
If errors occur in client console, those might help too.
Enable server logging if you must.
I've seen over many years people use FPP and ULX.
I don't know why it would just start happening without seeing errors.
Offline unown294
« Reply #2 on: August 29, 2015, 11:11:50 am »
That the Problem it crashes the game with out leaving any errors. But it doesnt crash the server it crashes the individuals game.
Offline roastchicken
  • I write code
« Reply #3 on: August 29, 2015, 01:03:15 pm »
Could you elaborate about what the 'admin button' is and what 'setting it' means?
Offline unown294
« Reply #4 on: August 29, 2015, 01:22:03 pm »
The admin button is for controlling admin features in Falco Prop Protection. I dont remember mentioning settings at all. so the moment we click the admin button in the Falco Prop Protection under the utilities tab we instantly crash our game.
Offline unown294
« Reply #5 on: August 31, 2015, 08:56:05 am »
Im just thinking of switching to URS Prop Re-stricter instead as its nots getting fixed anytime soon
« Reply #6 on: August 31, 2015, 11:15:59 am »
I'm running it and it works just fine man... might want to try reinstalling it.  Or try removing other addons that might be conflicting.
