Author Topic: Lots of console spammage, in need of help.  (Read 9628 times)
Wolfy
« on: May 22, 2007, 02:31:40 pm »
Hey there, I have recently tried to start up a Dedicated server, and it is . =P
I keep getting these errors over and over again:
Warning: Unhandled usermessage 'ulib_init'
Warning: Unhandled usermessage 'ULibUserUCL'
Warning: Unhandled usermessage 'ULibGroupUCL'
Warning: Unhandled usermessage 'ULibFinishedUCL'
Warning: Unhandled usermessage 'ULibLuaFn'
Warning: Unhandled usermessage 'ULXMotdText'
Warning: Unhandled usermessage 'SendMotdMenu'
Warning: Unhandled usermessage 'ULib_autocomplete'
Warning: Unhandled usermessage 'ulx_autocomplete'
Warning: Unhandled usermessage 'ulx_map'
I was wondering if someone could help.
Thanks
Wolfy
Re: Lots of console spammage, in need of help.
« Reply #1 on: May 22, 2007, 06:54:00 pm »
Most likely you're using script enforcer and it's not setup right.
To others: We really need to get a list of scripts needed for script enforcer. I'm sick of these topics :( (Can't do it myself, comp can't run GMod)
Wolfy
Re
« Reply #2 on: May 22, 2007, 08:33:47 pm »
I am running ZS on the server, If I missed a topic on this already I am sorry for uselessly doubling up topics.
I think ZS does use some sort of script enforcer, not sure why it is causeing this though, any ideas?
Offline atomicspark
« Reply #3 on: May 23, 2007, 12:27:49 am »
Yes!
Done!
/gamemodes/sandbox/clientscripts.txt
ULib/_cl_2.04/defines.lua
ULib/_cl_2.04/misc.lua
ULib/_cl_2.04/util.lua
ULib/_cl_2.04/tables.lua
ULib/_cl_2.04/messages.lua
ULib/_cl_2.04/player.lua
ULib/_cl_2.04/cl_util.lua
ULib/_cl_2.04/autocomplete.lua
ULib/_cl_2.04/draw.lua
ULib/_cl_2.04/concommand.lua
ULib/_cl_2.04/sh_ucl.lua
ULib/_cl_2.04/uroundmenu.lua
ULib/_cl_2.04/uroundbutton.lua
ULib/modules/ulx_init.lua
ulx/cl_init.lua
ulx/sh_defines.lua
ulx/cl_lib.lua
ulx/cl_menu.lua
« Last Edit: May 23, 2007, 09:29:38 pm by atomicspark »
« Reply #4 on: May 23, 2007, 06:59:30 am »
Thanks! I'll put that on a sticky
Wolfy
« Reply #5 on: May 23, 2007, 09:45:42 am »
Thanks much.
Wolfy
« Reply #6 on: May 23, 2007, 12:51:23 pm »
Okay, I put those lines in the correct file and it is still happening.
I also get this:
Timer Error: ULib/server/ucl.lua:601: attempt to index field '?' (a nil value)
Only once though. Is it a problem?
Offline spbogie
« Reply #7 on: May 23, 2007, 12:56:35 pm »
Actually Wolfy if you are running ZS you will need to add those lines to the userscripts.txt in the ZS gamemode directory.
Wolfy
« Reply #8 on: May 23, 2007, 09:18:34 pm »
Okay, I put everything where it is meant to be, but I am still getting the same errors, no matter what I try.
I have also been looking on pretty much every forum I can find for an answer, I see it come up quite a bit but if they have an answer it is always to add it into userscripts.txt or clientscripts.txt, this makes no difference for me.
Please someone help, unless there isn't a reason why it should be doing it.
Offline atomicspark
« Reply #9 on: May 23, 2007, 09:31:13 pm »
Oh sorry. My mistake. It's clientscripts.txt not userscripts.txt. Also put it under the correct gamemode. So not sandbox but... whatever your mod is calling it. Make sure you're doing this on the server.
Wolfy
« Reply #10 on: May 23, 2007, 11:02:42 pm »
Oh, I was putting it in the right place. It still didn't work, but you did sent me off on the right path.
In the end I came up with adding this to my clientscripts.txt:
autorun/ulib_init.lua
ULib/cl_init.lua
ULib/init.lua
ULib/_cl_2.04/_generator.lua
ULib/shared/concommand.lua
ULib/shared/defines.lua
ULib/shared/messages.lua
ULib/shared/misc.lua
ULib/shared/player.lua
ULib/shared/sh_ucl.lua
ULib/shared/tables.lua
ULib/shared/util.lua
ULib/client/autocomplete.lua
ULib/client/ul_util.lua
ULib/client/draw.lua
ULib/client/uroundbutton.lua
ULib/client/uroundmenu.lua
ULib/server/concommand.lua
ULib/server/entity_ext.lua
ULib/server/phys.lua
ULib/server/player.lua
ULib/server/player_ext.lua
ULib/server/ucl.lua
ULib/server/util.lua
ulx/cl_init/lua
ulx/init.lua
ulx/base.lua
ulx/cl_init.lua
ulx/cl_lib.lua
ulx/cl_menu.lua
ulx/end.lua
ulx/fun.lua
ulx/log.lua
ulx/sh_defines.lua
ulx/toolmode.lua
ulx/util.lua
ulx/vote.lua
ulx/sh_defines.lua
ulx/cl_lib.lua
ulx/cl_menu.lua
That unblocks every Ulib and ulx file. And no more errors, just nice startup messages now. ;D
Thanks guys.
« Reply #11 on: May 23, 2007, 11:09:14 pm »
Oops, looks like the only thing atomicspark was missing was the ulib init.
Try this wofly, and let us know if it works:
ULib/cl_init.lua
ulx/cl_init.lua
ulx/sh_defines.lua
ulx/cl_lib.lua
ulx/cl_menu.lua
« Last Edit: May 24, 2007, 12:19:02 am by Megiddo »
Offline atomicspark
« Reply #12 on: May 24, 2007, 12:21:22 am »
I missed two: "autorun/ulib_init.lua" and "ULib/cl_init.lua". They were hidden in my wire stuff. I have 913 lines of code, bare with me. :P
« Last Edit: May 24, 2007, 12:24:07 am by atomicspark »
« Reply #13 on: May 24, 2007, 06:31:51 pm »
Though knowing how to fix is nice, the pain of having to edit this everytime ULX or Ulib is updated would really bite.
