General
Developers Corner
help
Topic: help (Read 6338 times)
3RB
help
September 12, 2015, 06:34:23 am »
i have this addon from steam:
size manipulator
http://steamcommunity.com/sharedfiles/filedetails/?id=167808759&searchtext=size+manipulator
i want to make this addon for some ranks its for admin and up i want it for some ranks like owner,superadmin,admin+
how?
tell me what i will add to the lua to make it for some ranks not admin
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Re: help
September 12, 2015, 09:10:48 am »
You should ask the developer for assistance since we don't have access to see his code.
We can't see the code he uses, but you would need to add IsUserGroup checks to the line area that the author likely uses IsAdmin or IsSuperAdmin
JamminR
Ulysses Team Member
Re: help
Reply #2 on:
September 12, 2015, 10:01:17 am »
It seems you're wanting the work done for you, instead of learning and testing/doing some yourself.
I'm not that type of helper.
If you want to look through the code, find where the function(s) that have
IsSuperAdmin
and or
IsAdmin
and post that function here in a code block, we may be able to guide you how to add the
IsUserGroup
checks if you can't figure it out.
JamminR
Ulysses Team Member
Re: help
Reply #3 on:
September 12, 2015, 02:17:29 pm »
With the functions I mentioned in my previous post, where do you think we would edit the code?
There's one line, that checks to see if you have admin-only enabled in the addon settings, and then also checks to see if the player IsAdmin.
3RB
Re: help
Reply #4 on:
September 12, 2015, 05:31:16 pm »
T/C
General
Developers Corner
help
