Author Topic: cant change to groups and cant find any  (Read 5609 times)
Offline xblastermaster1
« on: September 12, 2015, 09:52:05 pm »
so i have a server and i havent really been able to play it for a while and when i finally did get back on i was no longer owner and i cant change back to owner and i cant edit any of the groups and i dont know why can someone help.
Re: cant change to groups and cant find any
« Reply #1 on: September 12, 2015, 11:30:07 pm »
Use your server console.
If it's not recognized as being superadmin to control commands, then reset your ulx to factory following our FAQ section.
« Reply #2 on: September 13, 2015, 07:15:00 am »
ive resetted the folders to factory but nothing changed
« Reply #3 on: September 13, 2015, 07:30:20 am »
Then we have a FAQ for "having trouble with access?"
I'd recommend following it.
Though it's long and has several steps, if each step in turn doesn't work, it has a step that tells you how to give us, the community and devs, more information to help you.
If even the final step doesn't work properly, I'd recommend total server re-install, as it likely means your server was totally exploited, and has commands embedded that prevent you from being superadmin.
