Author Topic: Help please  (Read 7928 times)
Offline lampman13
Help please
« on: September 20, 2015, 12:25:07 pm »
ok so I want to make a menu with a background that makes things behind it blurry like this.
can anyone tell me how I would do this?
Re: Help please
« Reply #1 on: September 20, 2015, 12:40:55 pm »
make a panel, use DrawBackgroundBlur on it.
Offline lampman13
Re: Help please
« Reply #2 on: September 20, 2015, 12:47:25 pm »
Thanks for such a fast reply i tried that once but i think i was using it wrong but i thought it meant behind the panel what do I use for the start time thing? just a little confused sorry :P
Offline lampman13
Re: Help please
« Reply #3 on: September 20, 2015, 12:59:07 pm »
ok so i got that but how do i restrict the blur to just an area like a box? also sorry for looking like a kid someone spilt something on my keyboard and I have sticky keys
Re: Help please
« Reply #4 on: September 20, 2015, 01:37:48 pm »
Blur will limit itself to the size of your panel.
As for time, there is a perfect example in that link. Systemtime in panel init.
Set a var when you make the panel, use that time in the blur. Or even a second before for fun effect I'd guess.
Offline Professor_Smiley
Re: Help please
« Reply #5 on: September 28, 2015, 01:32:36 am »
It is possible to make a panel that blurs and fades into transparent then fades into blur again and so on? Then I will color it red. For my gamemode.
Offline roastchicken
  • I write code
Re: Help please
« Reply #6 on: September 28, 2015, 03:50:11 pm »
Lampman never replied, so I'd just like to ask if this actually works for anyone?
I've tried it, and it blurs my entire screen. Here is my code:
  1. local panel = vgui.Create( "DPanel" )
  2.
  3. panel:SetPos( 100, ScrH() - 100 )
  4. panel:SetSize( 100, 50 )
  5.
  6. function panel:Init()
  7.         self.startTime = SysTime()
  8. end
  9.
  10. function panel:Paint()
  11.         Derma_DrawBackgroundBlur( self, self.startTime )
  12. end
Offline Timmy
  • Code monkey
Re: Help please
« Reply #7 on: September 28, 2015, 08:59:26 pm »
Yes, I don't think DrawBackgroundBlur limits itself to the size of a panel. DisableClipping(true) prevents it from doing so.
Derma_DrawBackgroundBlur function: https://github.com/garrynewman/garrysmod/blob/ead2b4d7f05681e577935fef657d4a4d962091e6/garrysmod/lua/derma/derma_utils.lua#L10-L42
Simply removing the clipping prevention seems to give the effect OP desires though.
Visual preview: https://i.imgur.com/Y5JteOL.jpg
  1. -- Based off Derma_DrawBackgroundBlur
  2. local matBlurScreen = Material( "pp/blurscreen" )
  3.
  4. function Derma_DrawBackgroundBlurInside( panel )
  5.         local x, y = panel:LocalToScreen( 0, 0 )
  6.
  7.         surface.SetMaterial( matBlurScreen )
  8.         surface.SetDrawColor( 255, 255, 255, 255 )
  9.
  10.         for i=0.33, 1, 0.33 do
  11.                 matBlurScreen:SetFloat( "$blur", 5 * i ) -- Increase number 5 for more blur
  12.                 matBlurScreen:Recompute()
  13.                 if ( render ) then render.UpdateScreenEffectTexture() end
  14.                 surface.DrawTexturedRect( x * -1, y * -1, ScrW(), ScrH() )
  15.         end
  16.
  17.         -- The line below gives the background a dark tint
  18.         surface.SetDrawColor( 10, 10, 10, 150 )
  19.         surface.DrawRect( x * -1, y * -1, ScrW(), ScrH() )
  20. end
  21.
  22. -- Create custom VGUI Panel
  23. local PANEL = {}
  24.
  25. function PANEL:Init()
  26.         self:SetSize( 450, 350 )
  27.         self:Center()
  28. end
  29.
  30. local mat = Material( "pp/blurscreen" )
  31. function PANEL:Paint( w, h )
  32.         Derma_DrawBackgroundBlurInside( self )
  33.         draw.DrawText( "Blurred background", "Trebuchet24", w / 2, 12, Color( 255, 255, 255, 255 ), TEXT_ALIGN_CENTER )
  34. end
  35.
  36. vgui.Register( "DBlurredBackground", PANEL )
  37.
  38. -- Create and show custom panel
  39. vgui.Create( "DBlurredBackground" )
Edit: Fix grammar
« Last Edit: September 29, 2015, 02:10:11 pm by Timmy »
  • I write code
Re: Help please
« Reply #8 on: September 29, 2015, 07:37:25 pm »
Thank you Timmy! I was messing around with the function and even tried to make my own, but I quickly discovered that the blurscreen material was just a copy of the screen and thus couldn't just be resized.
