Author Topic: Auto-Demoting?  (Read 4003 times)
Offline CrossBoy
Auto-Demoting?
« on: September 26, 2015, 10:34:17 pm »
So on a deathrun server that everything SEEMS to be working fine with, there seems to be some strange problem. I made a bunch of groups in ulx, and it was all fine. I set it up so every group inherated from the group below, like jrmod then mod then jradmin and so on. However, and this happens with all ranks, randomly, we get demoted to user. There is nothing that says in chat or console that we were demoted, we just have nothing in xgui and our name in tab changed back to user. I really have no clue why this is happening, and the only errors we get are world geomotry errors:
 env_cubemap used on world geometry without rebuilding map. . ignoring: brick/offwllb
env_cubemap used on world geometry without rebuilding map. . ignoring: glass/glasswindow070c
env_cubemap used on world geometry without rebuilding map. . ignoring: cs_assault/pavement001a
env_cubemap used on world geometry without rebuilding map. . ignoring: concrete/concretefloor005a
env_cubemap used on world geometry without rebuilding map. . ignoring: concrete/concretefloor028a
env_cubemap used on world geometry without rebuilding map. . ignoring: vehicle/metaltrainglass001a
env_cubemap used on world geometry without rebuilding map. . ignoring: concrete/concretefloor033k
In case you were wondering:
We use nfoservers
The addons we use are:
Apple chat tags, CustomCommands (The one category one), motdgdadverts, Pointshop, ulx, and utime.
EDIT: Just to confirm, I did check and I have the most recent versions of ULX and ULIB.
« Last Edit: September 27, 2015, 04:49:32 pm by CrossBoy »
Re: Auto-Demoting?
« Reply #1 on: September 27, 2015, 06:35:12 am »
Just to verify, are you using the latest ulib and ulx from our Github repo?
If you're using some installation package nfoserver uses, I'm not sure they're always using latest.
(at least, I've seen that problem in past)
Offline CrossBoy
Re: Auto-Demoting?
« Reply #2 on: September 27, 2015, 04:48:56 pm »
Yes, I just checked and verified that it is the most recent versions of both.
