Author Topic: draw.DrawText  (Read 7756 times)
Offline Sweepyoface
draw.DrawText
« on: September 26, 2015, 11:46:58 pm »
Hello, I edited my completely working code, then I was greeted with this error.
[ERROR] addons/admin_stick/lua/admin_stick_base_funcs.lua:408: ')' expected near '<eof>'
  1. unknown - addons/admin_stick/lua/admin_stick_base_funcs.lua:0
Then I undid all the edits I made, saved it, and
What is happening?
Another thing.
draw.DrawText(DarkRP.getPhrase("lockdown_started"), "ScoreboardSubtitle", ScrW() * 0.5, ScrH() * 0.15, Color(cin * 255, 0, 255 - (cin * 255), 255), TEXT_ALIGN_CENTER )Isn't working. The default DarkRP lockdown text
draw.DrawNonParsedText(DarkRP.getPhrase("lockdown_started"), "ScoreboardSubtitle", chbxX, chboxY + chatBoxSize, Color(cin * 255, 0, 255 - (cin * 255), 255), TEXT_ALIGN_LEFT)Isn't even drawing anything.
Re: draw.DrawText
« Reply #1 on: September 27, 2015, 06:49:18 am »
The first part of your question is pretty clear - you likely managed to erase a ) (closing bracket) somewhere near line 408 in your code of that file.
EOF means end of file. Somewhere near line 408 there was a opening bracket in a statement or function and the ending one is missing between line 408 and eof.
Apologies, I won't be able to help you with the 2nd part of your question.
I'm sure many of our other community members should be able to.
Offline Sweepyoface
Re: draw.DrawText
« Reply #2 on: September 27, 2015, 04:04:50 pm »
Nope, I literally spammed ctrl z to go back to when it was working perfectly, and checked everything.
Offline Timmy
  • Code monkey
Re: draw.DrawText
« Reply #3 on: September 27, 2015, 04:31:16 pm »
It's easy to undo too much/little. :D
Would you mind posting your code here so we can help you find what's causing that error?
Re: draw.DrawText
« Reply #4 on: September 27, 2015, 06:15:53 pm »
Sweepyoface, You asked for help - ignoring those who willingly give it freely gets you no further.
There is no arguing that error.
The code is missing a closing parenthesis - the error message is quite clear in that respect.
408: ')' expected near '<eof>' in file  addons/admin_stick/lua/admin_stick_base_funcs.lua
Somewhere between 407 and end of the file, lua can't find a closing parenthesis to match a starting parenthesis.
Blame who you want for the error if not yourself, that doesn't change the fact the code is missing one.
« Last Edit: September 27, 2015, 06:18:25 pm by JamminR »
Offline Sweepyoface
Re: draw.DrawText
« Reply #5 on: September 27, 2015, 06:39:17 pm »
AddStickTool("[DarkRP] Toggle Lockdown", {
Description = "Turns lockdown on and off.",
Icon = "icon16/lock.png",
CanTarget = anything,
OnRun = function(Player, Target)
if GetGlobalBool("DarkRP_LockDown") then
SetGlobalBool("DarkRP_LockDown", false)
DarkRP.notifyAll(0, 3, DarkRP.getPhrase("lockdown_ended"))
DarkRP.printMessageAll(HUD_PRINTTALK, DarkRP.getPhrase("lockdown_ended"))
SetGlobalBool("DarkRP_LockDown", true)
DarkRP.notifyAll(0, 3, DarkRP.getPhrase("lockdown_started"))
DarkRP.printMessageAll(HUD_PRINTTALK, DarkRP.getPhrase("lockdown_started"))
for k, v in pairs (player.GetAll()) do
v:ConCommand("play npc/overwatch/cityvoice/f_confirmcivilstatus_1_spkr.wav\n")
end)
Proper formatting: http://prntscr.com/8l9mn3
« Last Edit: September 27, 2015, 06:41:17 pm by Sweepyoface »
Re: draw.DrawText
« Reply #6 on: September 27, 2015, 06:57:03 pm »
You need a closing parenthesis for the OnRun function.
You open an anonymous function declaration but never close it.
Place a closing parenthesis on the third "end".
I'm smart, don't worry about me. ;)
« Last Edit: September 27, 2015, 07:02:50 pm by Bytewave »
Offline Sweepyoface
Re: draw.DrawText
« Reply #7 on: September 27, 2015, 06:59:41 pm »
No, that closes the AddStickTool and gives me this.
[ERROR] addons/admin_stick/lua/admin_stick_base_funcs.lua:412: '}' expected (to close '{' at line 395) near ')'
None of my other tools have that, either.
It seems to be working fine now randomly. I'll update if something happens.
Re: draw.DrawText
« Reply #8 on: September 27, 2015, 07:02:28 pm »
Oh wait, I'm smart. Read that wrong.
Hopefully it stays fixed, I suppose. What would be nice is a dump of the entire file, on something like Ubuntu Pastebin. You might have an error higher up in the file.
Offline Sweepyoface
Re: draw.DrawText
« Reply #9 on: September 27, 2015, 07:17:07 pm »
Now I'm getting
on server restart and
[ERROR] addons/admin_stick/lua/admin_stick_base_funcs.lua:409: unfinished string near '<eof>'
when trying to use it.
Here it is: http://pastebin.ubuntu.com/12599425/
Offline Sweepyoface
Re: draw.DrawText
« Reply #10 on: September 27, 2015, 07:20:13 pm »
Now I just restarted and no problems at all. So confused.
Offline Sweepyoface
Re: draw.DrawText
« Reply #11 on: September 28, 2015, 03:07:14 pm »
Alright, this is what I had.
I added the line below printMessageAll and it gives me the ) expected near <eof>
                                draw.DrawNonParsedText("lockdown_started", "ScoreboardSubtitle", chbxX, chboxY + chatBoxSize, Color(cin * 255, 0, 255 - (cin * 255), 255), TEXT_ALIGN_LEFT)
This proves my code is fine and it's being screwed up somehow. The drawing also didn't work and it didn't run any code past that line (the sound)
I then remove that entire line to revert to the perfectly working code before, and it gives me the same error. I bet 99% if I restart the server there will be no more error. But if I edit the code and have it refresh, error, no matter what.
« Last Edit: September 28, 2015, 03:13:43 pm by Sweepyoface »
