Author Topic: DarkRP /setaccess limitations?  (Read 4198 times)
« on: September 27, 2015, 09:53:04 am »
So I'm a Developer of a server, and I'm fairly new to DarkRP, so I'm trying to figure out how to limit the command /setaccess.
Basically our Head Admin is supposed to have some access to /setaccess (he also has some access with ulx adduser) but I don't want him to be able to use /setaccess to set himself to anything he wants. I and the Owners trust him not to, but in case there is ever a new one or something, I don't want it to be a possibility. I just think it would be much easier if we limit it, is there any way to do it? I was looking in the lua file and found the setaccess command, but I couldn't find anything about limiting the groups you can add to. Can anyone help?
On another note, how can I make a ULX based tab menu (where when you right-click someone's name it gives you a list of commands you can do on them - ban, jail, etc., but instead it will execute a ULX command, instead of an FAdmin command).
Never mind.. we just decided to remove FAdmin completely.
« Last Edit: September 28, 2015, 01:38:40 pm by Masterbinkie »
