Author Topic: ULX commands aren't working  (Read 5055 times)
Jordan
« on: May 24, 2007, 02:06:04 pm »
Hello,
I've installed ULX/ULB and it works fine. I mean I've added my self as an admin and I can do everything i should be able to do.. Except no ulx ___ commands work. I can use !menu and !adminmenu but anyhing with ulx help, etc doesn't work. I've tried installing everything in the garrysmod folder. I've tried installing it in /lua manually, and I've put it in /addons, which is what seems to work, expect for the ulx command part. This is frustrating because I want to be able to add operators, etc.
I'm using gmod 10, it's a dedicated server.
Thanks for your time,
Jordan
Re: ULX commands aren't working
« Reply #1 on: May 24, 2007, 02:44:06 pm »
Just to make sure, you know it's "ulx help" in console and not "ulx_help", right?
If that's not the case, tell us if there's any errors in server and/or client console.
Jordan
« Reply #2 on: May 24, 2007, 07:28:11 pm »
Yes i used the right command, console doesn't say anything to me, besides print out what i said. It's not registering it as a command.
Offline spbogie
« Reply #3 on: May 24, 2007, 08:50:03 pm »
Jordan,
Are there any errors ( client or server ) when starting up/connecting?
