Author Topic: Problem with Uteam and question about playermodels  (Read 4186 times)
Offline Nekomi
  • Nya~
« on: October 06, 2015, 11:07:50 pm »
Hello.
I'm actually having a problem with Uteam, it's just... it doesn't work at all at its current version i think, and i can't find any update, someone had an alternative ?
About playermodels, i am looking somehow to hide my admin model (the one into my avata) from the playermodels menu, and if i remove the model from this menu, i cannot use it at all. Not even able to set it with !model. Any ideas ?
Edit: I also added a few more public playermodels but those doesn't show up into the playermodels menu, all i can do to set them is : !model
Or if there's a way to open a popup (wich will say "This model is set to Admin only") upon clicking on the admin model into the playermodel menu..?
If you need my files, ask me.
Thanks. :3
« Last Edit: October 07, 2015, 03:29:20 am by Nekomi »
Re: Problem with Uteam and question about playermodels
« Reply #1 on: October 07, 2015, 04:18:19 pm »
Hi.
Uteam is included with ULX now, and requires a sandbox server.
Are you running sandbox? Are you running from our Git repository?
As for your other questions, those would be for another section of the forums, likely Off-topic, or if you're editing the lua files, Developers corner.
Offline Nekomi
  • Nya~
« Reply #2 on: October 08, 2015, 07:05:36 am »
Hi.
I am running sandbox, yes.
And i am not sure about git, can't remember.
I'll check it out. Then i'll reply to you.
