UTeam > UTeam.txt (data folder) not loading and error
Topic: UTeam > UTeam.txt (data folder) not loading and error (Read 4604 times)
Nekomi
Nya~
October 09, 2015, 04:17:16 pm »
Hello, i'm encountering this error on my UTeam :
ULib queue error: lua/autorun/uteam.lua:28: attempt to index upvalue 'team_data' (a nil value)
Anyone already faced this problem ?
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Re: UTeam > UTeam.txt (data folder) not loading and error
October 09, 2015, 04:38:13 pm »
You're likely using a version years out of date and almost definitely not supported by Team Ulysses.
I'd recommend using our latest ULib and ULX from Github, which includes UTeam.
UTeam.lua has been included with ULX in addons/ulx/lua/ulx/modules for over 5 years now and;
1) doesn't use uteams.txt
2) the path you show indicates a non-supported version.
Not only have I never seen the error in my years here, Google, as of this posting, hasn't either specifically for that variable.
https://www.google.com/?gws_rd=ssl#q=%2Bsite:forums.ulyssesmod.net+uteam+upvalue
Last Edit: October 09, 2015, 04:41:10 pm by JamminR
Nekomi
Nya~
Reply #2 on:
October 09, 2015, 06:28:05 pm »
Uh, i finally found the button on the ulx menu
Thanks however.
JamminR
Ulysses Team Member
Reply #3 on:
October 09, 2015, 08:30:16 pm »
Then make sure to remove the /autorun/uteam.lua or addons/uteam if that's what you have.
