local CATEGORY_NAME = "Voting"
--Public vote--
if SERVER then ulx.convar( "voteEcho", "0", _, ULib.ACCESS_SUPERADMIN ) end -- Echo votes?
-- First, our helper function to make voting so much easier!
function ulx.doVote( title, options, callback, timeout, filter, noecho, ... )
timeout = timeout or 20
if ulx.voteInProgress then
Msg( "Error! ULX tried to start a vote when another vote was in progress!\n" )
return false
if not options[ 1 ] or not options[ 2 ] then
Msg( "Error! ULX tried to start a vote without at least two options!\n" )
return false
local voters = 0
local rp = RecipientFilter()
if not filter then
rp:AddAllPlayers()
voters = #player.GetAll()
for _, ply in ipairs( filter ) do
rp:AddPlayer( ply )
voters = voters + 1
umsg.Start( "ulx_vote", rp )
umsg.String( title )
umsg.Short( timeout )
ULib.umsgSend( options )
umsg.End()
ulx.voteInProgress = { callback=callback, options=options, title=title, results={}, voters=voters, votes=0, noecho=noecho, args={...} }
timer.Create( "ULXVoteTimeout", timeout, 1, ulx.voteDone )
return true
function ulx.voteCallback( ply, command, argv )
if not ulx.voteInProgress then
ULib.tsayError( ply, "There is not a vote in progress" )
return
if not argv[ 1 ] or not tonumber( argv[ 1 ] ) or not ulx.voteInProgress.options[ tonumber( argv[ 1 ] ) ] then
ULib.tsayError( ply, "Invalid or out of range vote." )
return
if ply.ulxVoted then
ULib.tsayError( ply, "You have already voted!" )
return
local echo = ULib.toBool( GetConVarNumber( "ulx_voteEcho" ) )
local id = tonumber( argv[ 1 ] )
ulx.voteInProgress.results[ id ] = ulx.voteInProgress.results[ id ] or 0
ulx.voteInProgress.results[ id ] = ulx.voteInProgress.results[ id ] + 1
ulx.voteInProgress.votes = ulx.voteInProgress.votes + 1
ply.ulxVoted = true -- Tag them as having voted
local str = ply:Nick() .. " voted for: " .. ulx.voteInProgress.options[ id ]
if echo and not ulx.voteInProgress.noecho then
ULib.tsay( _, str ) -- TODO, color?
ulx.logString( str )
if game.IsDedicated() then Msg( str .. "\n" ) end
if ulx.voteInProgress.votes >= ulx.voteInProgress.voters then
ulx.voteDone()
if SERVER then concommand.Add( "ulx_vote", ulx.voteCallback ) end
function ulx.voteDone( cancelled )
local players = player.GetAll()
for _, ply in ipairs( players ) do -- Clear voting tags
ply.ulxVoted = nil
local vip = ulx.voteInProgress
ulx.voteInProgress = nil
timer.Remove( "ULXVoteTimeout" )
if not cancelled then
ULib.pcallError( vip.callback, vip, unpack( vip.args, 1, 10 ) ) -- Unpack is explicit in length to avoid odd LuaJIT quirk.
-- End our helper functions
local function voteDone( t )
local results = t.results
local winner
local winnernum = 0
for id, numvotes in pairs( results ) do
if numvotes > winnernum then
winner = id
winnernum = numvotes
local str
if not winner then
str = "Vote results: No option won because no one voted!"
str = "Vote results: Option '" .. t.options[ winner ] .. "' won. (" .. winnernum .. "/" .. t.voters .. ")"
Msg( str .. "\n" )
function ulx.vote( calling_ply, title, ... )
ULib.tsayError( calling_ply, "There is already a vote in progress. Please wait for the current one to end.", true )
return
ulx.doVote( title, { ... }, voteDone )
ulx.fancyLogAdmin( calling_ply, "#A started a vote (#s)", title )
local vote = ulx.command( CATEGORY_NAME, "ulx vote", ulx.vote, "!vote" )
vote:addParam{ type=ULib.cmds.StringArg, hint="title" }
vote:addParam{ type=ULib.cmds.StringArg, hint="options", ULib.cmds.takeRestOfLine, repeat_min=2, repeat_max=10 }
vote:defaultAccess( ULib.ACCESS_ADMIN )
vote:help( "Starts a public vote." )
-- Stop a vote in progress
function ulx.stopVote( calling_ply )
ULib.tsayError( calling_ply, "There is no vote currently in progress.", true )
return
ulx.voteDone( true )
ulx.fancyLogAdmin( calling_ply, "#A has stopped the current vote." )
local stopvote = ulx.command( CATEGORY_NAME, "ulx stopvote", ulx.stopVote, "!stopvote" )
stopvote:defaultAccess( ULib.ACCESS_SUPERADMIN )
stopvote:help( "Stops a vote in progress." )
local function voteMapDone2( t, changeTo, ply )
local shouldChange = false
if t.results[ 1 ] and t.results[ 1 ] > 0 then
ulx.logServAct( ply, "#A approved the votemap" )
shouldChange = true
ulx.logServAct( ply, "#A denied the votemap" )
if shouldChange then
ULib.consoleCommand( "changelevel " .. changeTo .. "\n" )
local function voteMapDone( t, argv, ply )
local winner
local winnernum = 0
winner = id
local ratioNeeded = GetConVarNumber( "ulx_votemap2Successratio" )
local minVotes = GetConVarNumber( "ulx_votemap2Minvotes" )
local str
local changeTo
-- Figure out the map to change to, if we're changing
if #argv > 1 then
changeTo = t.options[ winner ]
changeTo = argv[ 1 ]
if (#argv < 2 and winner ~= 1) or not winner or winnernum < minVotes or winnernum / t.voters < ratioNeeded then
str = "Vote results: Vote was unsuccessful."
elseif ply:IsValid() then
str = "Vote results: Option '" .. t.options[ winner ] .. "' won, changemap pending approval. (" .. winnernum .. "/" .. t.voters .. ")"
ulx.doVote( "Accept result and changemap to " .. changeTo .. "?", { "Yes", "No" }, voteMapDone2, 30000, { ply }, true, changeTo, ply )
else -- It's the server console, let's roll with it
ULib.tsay( _, str )
return
function ulx.votemap2( calling_ply, ... )
local argv = { ... }
return
for i=2, #argv do
if ULib.findInTable( argv, argv[ i ], 1, i-1 ) then
ULib.tsayError( calling_ply, "Map " .. argv[ i ] .. " was listed twice. Please try again" )
return
if #argv > 1 then
ulx.doVote( "Change map to..", argv, voteMapDone, _, _, _, argv, calling_ply )
ulx.fancyLogAdmin( calling_ply, "#A started a votemap with options" .. string.rep( " #s", #argv ), ... )
ulx.doVote( "Change map to " .. argv[ 1 ] .. "?", { "Yes", "No" }, voteMapDone, _, _, _, argv, calling_ply )
ulx.fancyLogAdmin( calling_ply, "#A started a votemap for #s", argv[ 1 ] )
local votemap2 = ulx.command( CATEGORY_NAME, "ulx votemap2", ulx.votemap2, "!votemap2" )
votemap2:addParam{ type=ULib.cmds.StringArg, completes=ulx.maps, hint="map", error="invalid map \"%s\" specified", ULib.cmds.restrictToCompletes, ULib.cmds.takeRestOfLine, repeat_min=1, repeat_max=10 }
votemap2:defaultAccess( ULib.ACCESS_ADMIN )
votemap2:help( "Starts a public map vote." )
if SERVER then ulx.convar( "votemap2Successratio", "0.5", _, ULib.ACCESS_ADMIN ) end -- The ratio needed for a votemap2 to succeed
if SERVER then ulx.convar( "votemap2Minvotes", "3", _, ULib.ACCESS_ADMIN ) end -- Minimum votes needed for votemap2
local function voteKickDone2( t, target, time, ply, reason )
local shouldKick = false
ulx.logUserAct( ply, target, "#A approved the votekick against #T (" .. (reason or "") .. ")" )
shouldKick = true
ulx.logUserAct( ply, target, "#A denied the votekick against #T" )
if shouldKick then
if reason and reason ~= "" then
ULib.kick( target, "Vote kick successful. (" .. reason .. ")" )
ULib.kick( target, "Vote kick successful." )
local function voteKickDone( t, target, time, ply, reason )
local winner
local winnernum = 0
winner = id
local ratioNeeded = GetConVarNumber( "ulx_votekickSuccessratio" )
local minVotes = GetConVarNumber( "ulx_votekickMinvotes" )
local str
if winner ~= 1 or winnernum < minVotes or winnernum / t.voters < ratioNeeded then
str = "Vote results: User will not be kicked. (" .. (results[ 1 ] or "0") .. "/" .. t.voters .. ")"
if not target:IsValid() then
str = "Vote results: User voted to be kicked, but has already left."
str = "Vote results: User will now be kicked, pending approval. (" .. winnernum .. "/" .. t.voters .. ")"
ulx.doVote( "Accept result and kick " .. target:Nick() .. "?", { "Yes", "No" }, voteKickDone2, 30000, { ply }, true, target, time, ply, reason )
else -- Vote from server console, roll with it
str = "Vote results: User will now be kicked. (" .. winnernum .. "/" .. t.voters .. ")"
function ulx.votekick( calling_ply, target_ply, reason )
return
local msg = "Kick " .. target_ply:Nick() .. "?"
msg = msg .. " (" .. reason .. ")"
ulx.doVote( msg, { "Yes", "No" }, voteKickDone, _, _, _, target_ply, time, calling_ply, reason )
ulx.fancyLogAdmin( calling_ply, "#A started a votekick against #T (#s)", minutes, target_ply, reason )
ulx.fancyLogAdmin( calling_ply, "#A started a votekick against #T", minutes, target_ply )
local votekick = ulx.command( CATEGORY_NAME, "ulx votekick", ulx.votekick, "!votekick" )
votekick:addParam{ type=ULib.cmds.PlayerArg }
votekick:addParam{ type=ULib.cmds.StringArg, hint="reason", ULib.cmds.optional, ULib.cmds.takeRestOfLine, completes=ulx.common_kick_reasons }
votekick:defaultAccess( ULib.ACCESS_ADMIN )
votekick:help( "Starts a public kick vote against target." )
if SERVER then ulx.convar( "votekickSuccessratio", "0.6", _, ULib.ACCESS_ADMIN ) end -- The ratio needed for a votekick to succeed
if SERVER then ulx.convar( "votekickMinvotes", "2", _, ULib.ACCESS_ADMIN ) end -- Minimum votes needed for votekick
local function voteBanDone2( t, nick, steamid, time, ply, reason )
local shouldBan = false
ulx.fancyLogAdmin( ply, "#A approved the voteban against #s (#s minutes) (#s))", nick, time, reason or "" )
shouldBan = true
ulx.fancyLogAdmin( ply, "#A denied the voteban against #s", nick )
if shouldBan then
ULib.addBan( steamid, time, reason, nick, ply )
local function voteBanDone( t, nick, steamid, time, ply, reason )
local winner
local winnernum = 0
winner = id
local ratioNeeded = GetConVarNumber( "ulx_votebanSuccessratio" )
local minVotes = GetConVarNumber( "ulx_votebanMinvotes" )
local str
str = "Vote results: User will not be banned. (" .. (results[ 1 ] or "0") .. "/" .. t.voters .. ")"
reason = ("[ULX Voteban] " .. (reason or "")):Trim()
str = "Vote results: User will now be banned, pending approval. (" .. winnernum .. "/" .. t.voters .. ")"
ulx.doVote( "Accept result and ban " .. nick .. "?", { "Yes", "No" }, voteBanDone2, 30000, { ply }, true, nick, steamid, time, ply, reason )
str = "Vote results: User will now be banned. (" .. winnernum .. "/" .. t.voters .. ")"
Msg( str .. "\n" )
function ulx.voteban( calling_ply, target_ply, minutes, reason )
return
local msg = "Ban " .. target_ply:Nick() .. " for " .. minutes .. " minutes?"
ulx.doVote( msg, { "Yes", "No" }, voteBanDone, _, _, _, target_ply:Nick(), target_ply:SteamID(), minutes, calling_ply, reason )
ulx.fancyLogAdmin( calling_ply, "#A started a voteban of #i minute(s) against #T (#s)", minutes, target_ply, reason )
ulx.fancyLogAdmin( calling_ply, "#A started a voteban of #i minute(s) against #T", minutes, target_ply )
local voteban = ulx.command( CATEGORY_NAME, "ulx voteban", ulx.voteban, "!voteban" )
voteban:addParam{ type=ULib.cmds.PlayerArg }
voteban:addParam{ type=ULib.cmds.NumArg, min=0, default=1440, hint="minutes", ULib.cmds.allowTimeString, ULib.cmds.optional }
voteban:addParam{ type=ULib.cmds.StringArg, hint="reason", ULib.cmds.optional, ULib.cmds.takeRestOfLine, completes=ulx.common_kick_reasons }
voteban:defaultAccess( ULib.ACCESS_ADMIN )
voteban:help( "Starts a public ban vote against target." )
if SERVER then ulx.convar( "votebanSuccessratio", "0.7", _, ULib.ACCESS_ADMIN ) end -- The ratio needed for a voteban to succeed
if SERVER then ulx.convar( "votebanMinvotes", "3", _, ULib.ACCESS_ADMIN ) end -- Minimum votes needed for voteban
-- Our regular votemap command
local votemap = ulx.command( CATEGORY_NAME, "ulx votemap", ulx.votemap, "!votemap" )
votemap:addParam{ type=ULib.cmds.StringArg, completes=ulx.votemaps, hint="map", ULib.cmds.takeRestOfLine, ULib.cmds.optional }
votemap:defaultAccess( ULib.ACCESS_ALL )
votemap:help( "Vote for a map, no args lists available maps." )
-- Our veto command
local veto = ulx.command( CATEGORY_NAME, "ulx veto", ulx.votemapVeto, "!veto" )
veto:defaultAccess( ULib.ACCESS_ADMIN )
veto:help( "Veto a successful votemap." )
