Author Topic: How to stop admins picking up above ULX ranks  (Read 14937 times)
Offline [NG:A] The Skrub King
« on: October 16, 2015, 11:38:30 am »
Hi all,
I have seen other posts about this, but I simply didnt understand it, but basically I want it so that moderators cant pick up admins, and admins cant pick up superadmins, and superadmins cant pick up co-owners, and co-owners cant pick up owners through ULX.
Thanks
Offline monkeymacman
Re: How to stop admins picking up above ULX ranks
« Reply #1 on: October 16, 2015, 02:13:29 pm »
Pretty sure it's already like that if you have inheritance/targeting set up right.
Have owner inherit from co-owner, co-owner inherit from superadmin, superadmin inherit from admin, admin inherit from moderator, and so on. Then just have each rank be able to target only their ranks and ranks below them, you can do this as follows:
Moderator be able to target "%admin", admin able to target "%superadmin" and so on. If this doesn't work for you then you might have a different addon that handles players picking up players, or I might be forgetting how physgunplayers works. I hope this helped you.
« Reply #2 on: October 16, 2015, 04:25:51 pm »
Okay thanks, I am tired now so I will go to bed now, but I will try it out in the morning, I know what you are on about, and this makes a lot of sense.
I will come back with results tomoz thanls :D
Offline Professor_Smiley
« Reply #3 on: October 17, 2015, 10:20:26 am »
Go to ULX and manage groups. Change admin can target to admin. Don't make it superadmin
« Reply #4 on: October 17, 2015, 12:47:07 pm »
The %group thing makes it so they can target any groups below that group. Which is just useful if you want to be able to have multiple ranks on the same level as each other.
Offline Caustic Soda-Senpai
    • Steam Page
« Reply #5 on: October 18, 2015, 12:40:42 am »
Its !%group
« Reply #6 on: October 18, 2015, 07:15:13 am »
Its !%group
For higher groups, yes; monkeymacman's answer sounds plausible in our inheritance chain.
To be honest, I've never tried it that way.
« Reply #7 on: October 19, 2015, 11:08:40 am »
Okay, I only have just come back to this, and I have tried both ways, I have tried monkeymacmans idea, as well as caustics idea, and neither worked they can still pick me up, is there anything else I can try?
    • Steam Page
« Reply #8 on: October 19, 2015, 11:49:21 am »
Is the gamemode DarkRP? Do you still have FAdmin enabled?
« Reply #9 on: October 19, 2015, 12:58:58 pm »
the gamemode is darkrp, and how do i disable fadmin?
    • Steam Page
« Reply #10 on: October 19, 2015, 05:29:15 pm »
1. Make sure the DarkRPMod is installed
2. In the darkrpmod, open lua\darkrp_config\disabled_defaults.lua with a text editor (preferably Sublime text or Notepad++, the Windows notepad program tends to mess things up)
3. In that file you should see something like this:
  1. /*---------------------------------------------------------------------------
  2. The list of modules that are disabled. Set to true to disable, false to enable.
  3. Modules that are not in this list are enabled by default.
  4. ---------------------------------------------------------------------------*/
  5. DarkRP.disabledDefaults["modules"] = {
  6.         ["afk"]              = true,
  7.         ["chatsounds"]       = false,
  8.         ["events"]           = false,
  9.         ["fpp"]              = false,
  10.         ["f1menu"]           = false,
  11.         ["f4menu"]           = false,
  12.         ["hitmenu"]          = false,
  13.         ["hud"]              = false,
  14.         ["hungermod"]        = true,
  15.         ["playerscale"]      = false,
  16.         ["sleep"]            = false,
  17.         ["fadmin"]           = false,
  18. }
4. Simply change the "false" next to ["fadmin"] to "true". After you're done, that line should look like this:
  1. ["fadmin"]           = true,
5. Done.
Taken from DarkRP Documentation
Hope it helps!
« Reply #11 on: October 19, 2015, 07:58:52 pm »
We also point to the how to disable DarkRP's Fadmin in our FAQ section of the forums.
Please make sure to review it.
« Reply #12 on: October 20, 2015, 01:52:19 pm »
thanks for the help guys it worked the !% worked, but i also tried that before, but before i didnt disable fadmin, which may have been why.
