-- This module holds any type of chatting functions
CATEGORY_NAME = "Chat"
------------------------------ Psay ------------------------------
function ulx.psay( calling_ply, target_ply, message )
ulx.fancyLog( { target_ply, calling_ply }, "#P to #P: " .. message, calling_ply, target_ply )
local psay = ulx.command( CATEGORY_NAME, "ulx psay", ulx.psay, "!p", true )
psay:addParam{ type=ULib.cmds.PlayerArg, target="!^", ULib.cmds.ignoreCanTarget }
psay:addParam{ type=ULib.cmds.StringArg, hint="message", ULib.cmds.takeRestOfLine }
psay:defaultAccess( ULib.ACCESS_ALL )
psay:help( "Send a private message to target." )
------------------------------ Asay ------------------------------
local seeasayAccess = "ulx seeasay"
if SERVER then ULib.ucl.registerAccess( seeasayAccess, ULib.ACCESS_OPERATOR, "Ability to see 'ulx asay'", "Other" ) end -- Give operators access to see asays echoes by default
function ulx.asay( calling_ply, message )
local format
local me = "/me "
if message:sub( 1, me:len() ) == me then
format = "(ADMINS) *** #P #s"
message = message:sub( me:len() + 1 )
format = "#P to admins: #s"
local players = player.GetAll()
for i=#players, 1, -1 do
local v = players[ i ]
if not ULib.ucl.query( v, seeasayAccess ) and v ~= calling_ply then -- Calling player always gets to see the echo
table.remove( players, i )
ulx.fancyLog( players, format, calling_ply, message )
local asay = ulx.command( CATEGORY_NAME, "ulx asay", ulx.asay, "@", true, true )
asay:addParam{ type=ULib.cmds.StringArg, hint="message", ULib.cmds.takeRestOfLine }
asay:defaultAccess( ULib.ACCESS_ALL )
asay:help( "Send a message to currently connected admins." )
------------------------------ Tsay ------------------------------
function ulx.tsay( calling_ply, message )
ULib.tsay( _, message )
if util.tobool( GetConVarNumber( "ulx_logChat" ) ) then
ulx.logString( string.format( "(tsay from %s) %s", calling_ply:IsValid() and calling_ply:Nick() or "Console", message ) )
local tsay = ulx.command( CATEGORY_NAME, "ulx tsay", ulx.tsay, "@@", true, true )
tsay:addParam{ type=ULib.cmds.StringArg, hint="message", ULib.cmds.takeRestOfLine }
tsay:defaultAccess( ULib.ACCESS_ADMIN )
tsay:help( "Send a message to everyone in the chat box." )
------------------------------ Csay ------------------------------
function ulx.csay( calling_ply, message )
ULib.csay( _, message )
ulx.logString( string.format( "(csay from %s) %s", calling_ply:IsValid() and calling_ply:Nick() or "Console", message ) )
local csay = ulx.command( CATEGORY_NAME, "ulx csay", ulx.csay, "@@@", true, true )
csay:addParam{ type=ULib.cmds.StringArg, hint="message", ULib.cmds.takeRestOfLine }
csay:defaultAccess( ULib.ACCESS_ADMIN )
csay:help( "Send a message to everyone in the middle of their screen." )
------------------------------ Thetime ------------------------------
local waittime = 60
local lasttimeusage = -waittime
function ulx.thetime( calling_ply )
if lasttimeusage + waittime > CurTime() then
ULib.tsayError( calling_ply, "I just told you what time it is! Please wait " .. waittime .. " seconds before using this command again", true )
return
lasttimeusage = CurTime()
ulx.fancyLog( "The time is now #s.", os.date( "%I:%M %p") )
local thetime = ulx.command( CATEGORY_NAME, "ulx thetime", ulx.thetime, "!thetime" )
thetime:defaultAccess( ULib.ACCESS_ALL )
thetime:help( "Shows you the server time." )
------------------------------ Adverts ------------------------------
ulx.adverts = ulx.adverts or {}
local adverts = ulx.adverts -- For XGUI, too lazy to change all refs
local function doAdvert( group, id )
if adverts[ group ][ id ] == nil then
if adverts[ group ].removed_last then
adverts[ group ].removed_last = nil
id = 1
id = #adverts[ group ]
local info = adverts[ group ][ id ]
local message = string.gsub( info.message, "%%curmap%%", game.GetMap() )
message = string.gsub( message, "%%host%%", GetConVarString( "hostname" ) )
message = string.gsub( message, "%%ulx_version%%", ulx.getVersion() )
if not info.len then -- tsay
local lines = ULib.explode( "\\n", message )
for i, line in ipairs( lines ) do
local trimmed = line:Trim()
if trimmed:len() > 0 then
ULib.tsayColor( _, true, info.color, trimmed ) -- Delaying runs one message every frame (to ensure correct order)
ULib.csay( _, message, info.color, info.len )
ULib.queueFunctionCall( function()
local nextid = math.fmod( id, #adverts[ group ] ) + 1
timer.Remove( "ULXAdvert" .. type( group ) .. group )
timer.Create( "ULXAdvert" .. type( group ) .. group, adverts[ group ][ nextid ].rpt, 1, function() doAdvert( group, nextid ) end )
end )
-- Whether or not it's a csay is determined by whether there's a value specified in "len"
function ulx.addAdvert( message, rpt, group, color, len )
local t
if group then
t = adverts[ tostring( group ) ]
if not t then
t = {}
adverts[ tostring( group ) ] = t
group = table.insert( adverts, {} )
t = adverts[ group ]
local id = table.insert( t, { message=message, rpt=rpt, color=color, len=len } )
if not timer.Exists( "ULXAdvert" .. type( group ) .. group ) then
timer.Create( "ULXAdvert" .. type( group ) .. group, rpt, 1, function() doAdvert( group, id ) end )
------------------------------ Gimp ------------------------------
local gimpSays = {} -- Holds gimp says
ulx.gimpSays = gimpSays -- For XGUI, too lazy to change all refs
local ID_GIMP = 1
local ID_MUTE = 2
function ulx.addGimpSay( say )
table.insert( gimpSays, say )
function ulx.clearGimpSays()
table.Empty( gimpSays )
function ulx.gimp( calling_ply, target_plys, should_ungimp )
for i=1, #target_plys do
local v = target_plys[ i ]
if should_ungimp then
v.gimp = nil
v.gimp = ID_GIMP
v:SetNWBool("ulx_gimped", not should_ungimp)
if not should_ungimp then
ulx.fancyLogAdmin( calling_ply, "#A gimped #T", target_plys )
ulx.fancyLogAdmin( calling_ply, "#A ungimped #T", target_plys )
local gimp = ulx.command( CATEGORY_NAME, "ulx gimp", ulx.gimp, "!gimp" )
gimp:addParam{ type=ULib.cmds.PlayersArg }
gimp:addParam{ type=ULib.cmds.BoolArg, invisible=true }
gimp:defaultAccess( ULib.ACCESS_ADMIN )
gimp:help( "Gimps target(s) so they are unable to chat normally." )
gimp:setOpposite( "ulx ungimp", {_, _, true}, "!ungimp" )
------------------------------ Mute ------------------------------
function ulx.mute( calling_ply, target_plys, should_unmute )
if should_unmute then
v.gimp = nil
v.gimp = ID_MUTE
v:SetNWBool("ulx_muted", not should_unmute)
if not should_unmute then
ulx.fancyLogAdmin( calling_ply, "#A muted #T", target_plys )
ulx.fancyLogAdmin( calling_ply, "#A unmuted #T", target_plys )
local mute = ulx.command( CATEGORY_NAME, "ulx mute", ulx.mute, "!mute" )
mute:addParam{ type=ULib.cmds.PlayersArg }
mute:addParam{ type=ULib.cmds.BoolArg, invisible=true }
mute:defaultAccess( ULib.ACCESS_ADMIN )
mute:help( "Mutes target(s) so they are unable to chat." )
mute:setOpposite( "ulx unmute", {_, _, true}, "!unmute" )
if SERVER then
local function gimpCheck( ply, strText )
if ply.gimp == ID_MUTE then return "" end
if ply.gimp == ID_GIMP then
if #gimpSays < 1 then return nil end
return gimpSays[ math.random( #gimpSays ) ]
hook.Add( "PlayerSay", "ULXGimpCheck", gimpCheck, HOOK_LOW )
------------------------------ Gag ------------------------------
function ulx.gag( calling_ply, target_plys, should_ungag )
v.ulx_gagged = not should_ungag
v:SetNWBool("ulx_gagged", v.ulx_gagged)
if not should_ungag then
ulx.fancyLogAdmin( calling_ply, "#A gagged #T", target_plys )
ulx.fancyLogAdmin( calling_ply, "#A ungagged #T", target_plys )
local gag = ulx.command( CATEGORY_NAME, "ulx gag", ulx.gag, "!gag" )
gag:addParam{ type=ULib.cmds.PlayersArg }
gag:addParam{ type=ULib.cmds.BoolArg, invisible=true }
gag:defaultAccess( ULib.ACCESS_ADMIN )
gag:help( "Gag target(s), disables microphone." )
gag:setOpposite( "ulx ungag", {_, _, true}, "!ungag" )
local function gagHook( listener, talker )
if talker.ulx_gagged then
return false
hook.Add( "PlayerCanHearPlayersVoice", "ULXGag", gagHook )
-- Anti-spam stuff
if SERVER then
local chattime_cvar = ulx.convar( "chattime", "1.5", "<time> - Players can only chat every x seconds (anti-spam). 0 to disable.", ULib.ACCESS_ADMIN )
local function playerSay( ply )
if not ply.lastChatTime then ply.lastChatTime = 0 end
local chattime = chattime_cvar:GetFloat()
if chattime <= 0 then return end
if ply.lastChatTime + chattime > CurTime() then
return ""
ply.lastChatTime = CurTime()
return
hook.Add( "PlayerSay", "ulxPlayerSay", playerSay, HOOK_LOW )
local function showWelcome( ply )
local message = GetConVarString( "ulx_welcomemessage" )
if not message or message == "" then return end
message = string.gsub( message, "%%curmap%%", game.GetMap() )
ply:ChatPrint( message ) -- We're not using tsay because ULib might not be loaded yet. (client side)
hook.Add( "PlayerInitialSpawn", "ULXWelcome", showWelcome )
if SERVER then ulx.convar( "welcomemessage", "", "<msg> - This is shown to players on join.", ULib.ACCESS_ADMIN ) end
