Author Topic: Jailbreak force swap ULX  (Read 6070 times)
Offline Aeioyoo
« on: October 25, 2015, 11:55:46 pm »
Where do I set which ULX groups can force swap players teams in the Tab menu in Jailbreak by Excl?
Thanks!
« Last Edit: October 26, 2015, 07:57:43 pm by JamminR »
Offline Caustic Soda-Senpai
    • Steam Page
Re: Jailbreak force swap ULX
« Reply #1 on: October 25, 2015, 11:59:36 pm »
In the permissions under each group in the groups tab.
Offline Aeioyoo
« Reply #2 on: October 26, 2015, 12:01:09 am »
I looked in the XGUI group tab and cant find it anywhere? Whats it under?
Offline roastchicken
  • I write code
« Reply #3 on: October 26, 2015, 01:21:11 pm »
Excl's Jailbreak does not check for ULX permissions for the tab menu forceswap. It just runs LocalPlayer():IsAdmin(). You could change this to look for a ULX permission, using ULib.ucl.query( player, permission ).
The code you want to change is on line 127 in gamemodes/jailbreak/gamemode/core/cl_scoreboard.lua
« Last Edit: October 26, 2015, 07:57:58 pm by JamminR »
« Reply #4 on: October 26, 2015, 07:56:51 pm »
Or you could just have the command run as intended, for admins only, and give those who you trust with admin access the admin group.
Don't just give that out frivolously though. Admin access to a server can kill a server if someone wasn't properly responsible.
Offline Buzzkill
    • The Hundred Acre Bloodbath
« Reply #5 on: October 27, 2015, 11:42:44 am »
Not a true swap, but something to work with anyway...
------------------------------ Make Prisoner------------------------------
function ulx.makeprisoner( calling_ply, target_plys )
local affected_plys = {}
for i=1, #target_plys do
local v = target_plys[ i ]
if ulx.getExclusive( v, calling_ply ) then
ULib.tsayError( calling_ply, ulx.getExclusive( v, calling_ply ), true )
//elseif not v:Alive() then
// ULib.tsayError( calling_ply, v:Nick() .. " is already dead!", true )
elseif v:IsFrozen() then
ULib.tsayError( calling_ply, v:Nick() .. " is frozen!", true )
v:KillSilent()
v:SetTeam(TEAM_PRISONER)
v.AllowRespawn = true
v:Spawn();
table.insert( affected_plys, v )
ulx.fancyLogAdmin( calling_ply, "#A changed the team of #T", affected_plys )
local makeprisoner = ulx.command( CATEGORY_NAME, "ulx makeprisoner", ulx.makeprisoner, "!makeprisoner" )
makeprisoner:addParam{ type=ULib.cmds.PlayersArg }
makeprisoner:defaultAccess( ULib.ACCESS_ADMIN )
makeprisoner:help( "Changes the team of the target(s) to prisoner." )
------------------------------ Make Guard ------------------------------
function ulx.makeguard( calling_ply, target_plys )
v:KillSilent()
v:SetTeam(TEAM_GUARD)
v:Spawn();
local makeguard = ulx.command( CATEGORY_NAME, "ulx makeguard", ulx.makeguard, "!makeguard" )
makeguard:addParam{ type=ULib.cmds.PlayersArg }
makeguard:defaultAccess( ULib.ACCESS_ADMIN )
makeguard:help( "Changes the team of the target(s) to prisoner." )
------------------------------ Make Warden ------------------------------
function ulx.makewarden( calling_ply, target_plys )
local warden=JB.TRANSMITTER:GetJBWarden()
if IsValid(warden) then
warden:RemoveWardenStatus();
table.insert( affected_plys, warden )
v:KillSilent()
v:Spawn();
v:AddWardenStatus();
ulx.fancyLogAdmin( calling_ply, "#A forced warden #T", affected_plys )
local makewarden = ulx.command( CATEGORY_NAME, "ulx makewarden", ulx.makewarden, "!makewarden" )
makewarden:addParam{ type=ULib.cmds.PlayersArg }
makewarden:defaultAccess( ULib.ACCESS_ADMIN )
makewarden:help( "Force warden of the target(s)." )
