Author Topic: lua error when someone joins  (Read 4463 times)
Offline acidtownx
« on: October 29, 2015, 09:28:56 pm »
Hey guys, this lua error shows up in the console whenever I or someone else tries to join:
[ERROR] addons/ulx/lua/ulx/modules/cl/xgui_client.lua:184: attempt to index field 'settings_tabs' (a nil value)
  1. processModules - addons/ulx/lua/ulx/modules/cl/xgui_client.lua:184
   2. fn - addons/ulx/lua/ulx/modules/cl/xgui_client.lua:158
    3. Call - addons/ulib/lua/ulib/shared/hook.lua:179
     4. fn - addons/ulib/lua/ulib/cl_init.lua:48
      5. unknown - addons/ulib/lua/ulib/shared/hook.lua:179
I didn't edit any of the settings. I would post the xgui_client but it will be well over 20000 characters so here's a pastebin instead: http://pastebin.com/Ey74EgmN
Any help is appreciated! Thanks!
Re: lua error when someone joins
« Reply #1 on: October 30, 2015, 10:13:32 am »
That's odd- have you modified or removed any ULX or XGUI files on your server? Your file doesn't seem to match our current version, so I highly recommend updating from our GitHub page if you can.
Offline acidtownx
« Reply #2 on: October 30, 2015, 03:14:29 pm »
Nope. Although, in my web hosted server, I wasn't able to extract it and had to input each file individually. Double checked everything and it matches with the file locations and such. I will get the file from the github page and post an update soon :)
EDIT: It seems like I downloaded the ulx from the github since I tried downloading it and it had the same file name. I just replaced it and put the files back in and it now works! Not sure what happened but the error doesn't show up anymore. Thanks a lot!  :)
« Last Edit: October 30, 2015, 09:27:33 pm by acidtownx »
« Reply #3 on: October 30, 2015, 10:07:12 pm »
Glad you got it figured out!  ;D
