Author Topic: Ulx 3.1 and server.ini  (Read 8522 times)
Offline OvLoV
« on: May 29, 2007, 12:56:33 pm »
Yeah I read the readme file   ;)
I am just wondering why I don't get the server.ini loaded after starting my listen server.
Everybody misses that nice adverts: ulx addAdvert isn't loaded  :-\
Now it's located at addons\ulx\lua\ulx\configs folder
Any idea? I also tried to rename it to sandbox.ini after placing it in the ...\gamemodes folder
Re: Ulx 3.1 and server.ini
« Reply #1 on: May 29, 2007, 01:32:04 pm »
If it can't find the file it gives you an error on ulx load. Tell us if you have other errors in console as well.
Offline OvLoV
« Reply #2 on: May 29, 2007, 02:15:04 pm »
Don't know if it has anything to do with ULX/Ulib but this is what a get from the console after stating up:
Lua initialized (Lua 5.1)
ERROR! Module 'ulib' not found!
//  shared/tabl`
===  Wire  0.98   Installed  ===
1 active EHandles!
ScriptEnforce: gamemodes/sandbox/clientscripts.txt wasn't found. This gamemode is unprotected.
Unknown command "ulx"
Joining Game..
[UCL] Access set.
This server is running ULib version 2.04.
--- Missing Vgui material noting
« Reply #3 on: May 29, 2007, 07:10:50 pm »
There's no way a print is going to be cut off mid-line. Give us the full output.
Offline OvLoV
« Reply #4 on: May 30, 2007, 12:57:22 am »
Ok here it is:
Mounting Apps From /settings/mount/*.txt
   Mounting App 240 (cstrike) - Ok!
   Mounting App 300 (dod) - Not Installed!
   Mounting App 340 (lostcoast) - Ok!
   Mounting App 220 (hl2) - Ok!
   Mounting App 380 (episodic) - Not Installed!
   Mounting App 320 (hl2mp) - Ok!
   Mounting App 280 (hl1) - No Permission!
   Mounting App 360 (hl1mp) - Not Installed!
Done!
Not mounting addon/gamemode 'day-of-defeat', requires missing GCF file (300)
Parent cvar in server.dll not allowed (sk_apc_missile_damage)
Both ConVars must be marked FCVAR_REPLICATED for linkage to work (r_VehicleViewDampen)
Garry's Mod client.dll Build #0027 [May 17 2007 16:35:02]
maxplayers set to 1
Heap: 256.00 Mb
Parsed 23 text messages
Adding Font resource/fonts/akbar.ttf
Adding Font resource/fonts/coolvetica.ttf
Adding Font resource/fonts/csd.ttf
Adding Font resource/fonts/lynx.ttf
Render Targets.. Done!
Couldn't find custom font file 'resource/HL2EP2.ttf'
Couldn't find custom font file 'materials/vgui/fonts/buttons_32.vbf'
Garry's Mod server.dll Build #0027 [May 17 2007 16:35:01]
execing config.cfg
Can't use cheat cvar dsp_dist_max in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar dsp_dist_min in multiplayer, unless the server has sv_cheats set to 1.
2 CPUs, Frequency: 1.9 Ghz,  Features: GenuineIntel SSE SSE2 MMX RDTSC CMOV FCMOV
GetAllManifestFiles:  Unable to load maplist.txt
execing valve.rc
execing autoexec.cfg
Starting Level gm_flatgrass (Gamemode Override '')
maxplayers set to 4
Unknown command "sbox_allownpcs"
Unknown command "sbox_maxprops"
Unknown command "sbox_maxragdolls"
Unknown command "sbox_maxnpcs"
Unknown command "sbox_maxballoons"
Unknown command "sbox_maxeffects"
Unknown command "sbox_maxdynamite"
Unknown command "sbox_maxlamps"
Unknown command "sbox_maxthrusters"
Unknown command "sbox_maxwheels"
Unknown command "sbox_godmode"
Unknown command "sbox_plpldamage"
Unknown command "sbox_playergod"
Unknown command "sbox_noclip"
Unknown command "sbox_maxhoverballs"
Unknown command "sbox_maxvehicles"
Unknown command "sbox_maxbuttons"
Unknown command "sbox_maxsents"
Unknown command "sbox_maxemitters"
Unknown command "sbox_maxspawners"
Unknown command "sbox_maxturrets"
Unknown command "contraptionary_intermission_time"
Unknown command "contraptionary_guess_time"
Unknown command "contraptionary_max_guesses"
execing game.cfg
Network: IP 192.*.*.*, mode MP, dedicated No, ports 27015 SV / 27005 CL  >Changed by me!<
Spawn Server gm_flatgrass
Begin loading faces (loads materials)
End loading faces (loads materials)
//  shared/concommand.lua    //
//  shared/sh_ucl.lua         //
[ULIB] Loading module: ulx_init.lua
//  util.lua                 //
//  fun.lua                  //
//  vote.lua                 //
//  toolmode.lua             //
//  slots.lua                //
==== Advanced Duplicator v.1.614 shared module installed! ====
==== Advanced Duplicator v.1.71 server module installed! ====
==== Advanced Duplicator v.1.62.2 debug duplicator module installed! ====
1 active EHandles!
execing ulx_aliases.cfg
execing skill_manifest.cfg
execing skill.cfg
Executing listen server config file
Section [Scenes]: 1096 resources total 17.54 KB, 0.84 % of limit (2.10 MB)
4 player server started
couldn't exec listenserver.cfg
Adding master server 72.165.61.189:27011
Adding master server 72.165.61.190:27011
Client "OvLoV" connected (127.0.0.1:27005).
Connected to 127.0.0.1:27015
Connection to Steam servers successful.
   VAC secure mode is activated.
[L] Sandbox
Map: gm_flatgrass
Players:  1 / 4
Build 3056
Server Number 1
Initializing renderer...
Precaching Spawn Icons... DONE!
--- Missing Vgui material vgui/entities/weapon_annabelle
--- Missing Vgui material vgui/entities/weapon_alyxgun
--- Missing Vgui material vgui/entities/weapon_citizenpackage
--- Missing Vgui material vgui/entities/weapon_citizensuitcase
Server is running Garry's Mod Version 27 - gamemode 'sandbox'
Waiting for String Tables..
Creating RT Texture 'GModToolgunScreen'..DONE!
==== Advanced Duplicator v.1.62.2 client module installed! ====
Joining Game..
[UCL] Access set.
ULX version 3.10 loaded.
Hope this will help!
Offline OvLoV
ulx/ulx server.ini part two
« Reply #5 on: May 31, 2007, 05:10:46 am »
Has anyone any idea where to put the server.ini file so that automatically it reads:
ulx showMotd
ulx mingekick
ulx chattime 1.5
ulx addCsayAdvert
ulx addAdvert
etc
etc
during startup gmod server.
Mine is placed in the folder: addons\ulx\lua\ulx\configs
unfortunately that doesn't seems to work :-\
Re: ulx/ulx server.ini part two
« Reply #6 on: May 31, 2007, 10:16:50 am »
Errors during startup?
Offline OvLoV
« Reply #7 on: May 31, 2007, 11:01:31 am »
See my former thread (msg)
The msg with the very long console txt dump
« Reply #8 on: May 31, 2007, 11:26:33 am »
Merged topics
Offline OvLoV
« Reply #9 on: June 02, 2007, 01:07:19 pm »
OK
if no one knows the answer it must be VISTA lol? :-\
