Errors (Supposedly) after Moving GitHub Repository Location
Topic: Errors (Supposedly) after Moving GitHub Repository Location (Read 4630 times)
nex86
November 18, 2015, 02:18:56 pm »
I updated ULX from the new locations,
Now I'm getting told in chat that I have to update ULX and also all the ranks are gone, I'am no longer a super admin anymore and anyone else lost their rank as well.
Megiddo
Ulysses Team Member
Project Lead
Re: Errors (Supposedly) after Moving GitHub Repository Location
November 18, 2015, 03:23:08 pm »
If you are being told to update ULX, you are not using the new location.
Your data (ranks/groups) are stored in the "data" folder at the gmod root. Not sure what you may have done to upset that unless you wiped your entire server folder.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #2 on:
November 18, 2015, 04:31:33 pm »
I could potentially see some other addon using our old location to verify.
That addon would need to update.
But, yeah, moving shouldn't touch your access.
EDIT, oh, and split/moved this topic. News announcement not place to troubleshoot.
nex86
Reply #3 on:
November 19, 2015, 08:27:52 am »
I accidently moved it into the data folder..
Problem solved now but there is another problem
Our loadingscreen is no longer working, it says that the steam ID was not given correctly by gmod.
I'm not sure if its ULX related or valve changed something during the last 2 days ...
Megiddo
Ulysses Team Member
Project Lead
Reply #4 on:
November 19, 2015, 09:01:25 am »
That does not sound ULX related.
