Author Topic: ULX and Wiremod  (Read 4580 times)
Offline saintlydemonic
ULX and Wiremod
« on: December 22, 2015, 10:25:54 pm »
Hello,
I use NFO and their Auto Installers.
On a fresh server ULX and ULIB works.
Once I install Wiremod, ulx/ulib only half works.
For example,
When making/editing custom groups.
Symptoms include:
    - Inheritance resetting to "User" directly after hitting "update"
    - Ability to see the group "no access" (Usually invisible)
    - Sometimes ULX wont even be processed as being a addon, therefore, making ULX menu and command inaccessible.
Anyone know what is going on?
Edit: Adding more info
- deleting the ulx and ulib addon and its data from data folder is possible but once you install ulx and ulib again it had the same data it did from before you deleted it. I dont get how that happens if you deleted its data it should have created a fresh set.
- Checked console log and no errors exsist
- I have tried manually installing both ulx/ulib and wiremod resulting with the same problem.
« Last Edit: December 22, 2015, 10:54:37 pm by saintlydemonic »
Re: ULX and Wiremod
« Reply #1 on: December 23, 2015, 06:19:50 am »
ULX and DarkRP had a bug that did this that both authors fixed a while ago. Sounds like you aren't running a recent version of either. Groups are carried over through a reset in DarkRP by CAMI. No access is a DarkRP group.
Re: ULX and Wiremod
« Reply #2 on: December 23, 2015, 02:26:28 pm »
DarkRP and ULX both are updated to their most recent version. Same error.
Re: ULX and Wiremod
« Reply #3 on: December 23, 2015, 02:48:12 pm »
Could we continue this thread on Facepunch? Thank you.
https://facepunch.com/showthread.php?t=1498639&p=49377392#post49377392
