Author Topic: Ulx pop up menu.  (Read 4517 times)
Offline gmodcentral
Ulx pop up menu.
« on: December 28, 2015, 05:11:46 pm »
So I just saw a server with a command to open a small menu with text and pictures in it and then exit out of it. It's a ULX command because it showed up in the xgui. Does anyone have a code for this? Also the server is GGG Toshkent, and the command is in the xgui.
Offline WispySkies
Re: Ulx pop up menu.
« Reply #1 on: December 28, 2015, 11:54:59 pm »
From what you said, I'm guessing it's a ULX command that triggers gui popups and Derma. If someone is willing to make it for you, good luck!
Offline roastchicken
  • I write code
« Reply #2 on: December 29, 2015, 01:05:54 am »
SticklyMan recently added a function for this, per my request (or maybe I'm just flattering myself). I'll see if I can whip this up when I have the time, hopefully in a few hours.
Nevermind, I completely misread the question. This is not a default ULX function, and likely something they coded themselves. I don't think anyone here can help you  :-\
« Last Edit: December 29, 2015, 02:42:53 am by roastchicken »
