Author Topic: MOTD Shows up blank on sandbox server  (Read 5626 times)
Offline TheSenDest
« on: January 01, 2016, 03:34:11 pm »
Hello,
I run a sandbox server hosted by NFO and I use FileZilla to file manage. I recently updated my SVN's to the new ULX and ULib trunks and I cannot, for the life of me, figure out how to make the MOTD work. I put it in addons/ulx & data/ ..
It used to go in the first path but now there are odd looking files that i've never seen before.
If anyone can help, it would be greatly appreciated!
Thank you, and happy new year. :)
Re: MOTD Shows up blank on sandbox server
« Reply #1 on: January 01, 2016, 03:39:41 pm »
Due to our migration to Workshop, we were forced to remove the MOTD file in the development version. We're working on approaching the MOTD differently, but for now it's disabled. You can download the old MOTD yourself and stick it at your garrysmod root though, and you should be good to go.
Offline TheSenDest
« Reply #2 on: January 01, 2016, 03:40:56 pm »
Where do I put the one you linked to? I have the exact same one and I put it in addons/ulx and it doesn't work.
Edit: Put my motd in garrysmod/  &  garrysmod/garrysmod and they both don't work.
« Last Edit: January 01, 2016, 04:00:08 pm by TheSenDest »
« Reply #3 on: January 01, 2016, 04:54:45 pm »
If 'ulx showMotd' is set to 1, it loads the file in the location specified by 'motdfile', both of which can be configured in XGUI. 'motdfile' defaults to 'ulx_motd.txt', which it looks for in the garry's mod root.
Offline TheSenDest
« Reply #4 on: January 03, 2016, 11:56:00 am »
Okay I got it to work on legacy(svn) then my prop-protection stopped working so I switched over to workshop and now prop-protection is working and the MOTD isn't.
I set "ulx showMotd" to 1 ("ulx showMotd" "1" is how it is in my server.cfg) and renamed the motd to 'ulx_motd.txt' in my garrysmod/garrysmod folder. Is there anything else I need to do at this point? Do I have to restart the server?
« Reply #5 on: January 03, 2016, 12:19:33 pm »
No, you don't need to restart the server. Did you put the motd in the root garrysmod directory?
Offline TheSenDest
« Reply #6 on: January 03, 2016, 01:04:45 pm »
...renamed the motd to 'ulx_motd.txt' in my garrysmod/garrysmod folder.
