Author Topic: SetSpawn not working.  (Read 5207 times)
Offline Skashh
« on: January 02, 2016, 11:40:51 am »
From what I know I have inheritance set correctly but for some reason when I try and do /setspawn {group} or /addspawn {group} it says "You don't have the right privileges to perform this action". It's getting really annoying cause this is the only thing I can't figure out.
Re: SetSpawn not working.
« Reply #1 on: January 02, 2016, 11:56:11 am »
Team Ulysses' Ulx doesn't include a setspawn command. ( /index.php/topic,3254.0.html )
If you have an addon that adds a set spawn command for ULX, you should ask in that appropriate release thread for the addon that does.
I took the 3 seconds to use the search function within the forum community releases section for the word "setspawn".
This link finds it in 3 different release topics. /index.php?action=search2;params=eJwtzDEOgCAQRNG72Nhq4XkILJOgQZYsKDHh8C7G7s8rxvrbJoLvc1_61J2MWjfNErgZ4jNHVCgOutwBqoZTfH5hqVqCiO_nJ-N3UfYoNARWKOguqCXbll6Jai5x
If you're not using those releases, then you may wish to research further and find your addon's support method.
« Last Edit: January 02, 2016, 12:00:50 pm by JamminR »
