Author Topic: UBan -- Global ban system. Ban users from all servers connected to a single DB!  (Read 168331 times)
Offline Sc00by22
 I have reinstalled Uban about 6 times, and i'm still getting "attempt to index global 'UBan' (a nil value)" Anything im doing wrong
Did you restart your server?
Offline Sc00by22
Yes
Offline Sc00by22
about 15h reinstall now, Still the same error
Offline Sc00by22
about 15th reinstall now, Still the same error
Ahh, This is a weird error, The file actually exists there because i check
ULib/modules/uban_ulx.lua:25: attempt to index global 'UBan' (a nil value)error loading module 'mysql' from file 'e:\udontneedtoknow\udontneedtoknow\udontneedtoknow\gameservers\udontneedtoknow\orangebox\garrysmod\lua\includes\modules\gmsv_mysql.dll':
   The specified module could not be found.
Do you have the SQL dll in your srcds.exe folder as well? (NOT gmsv_mysql.dll, it's a different one)
Offline Sc00by22
Hmm, I'll try that now
Offline Sc00by22
Works, Thanks so much
Offline LUADuck
Hmm, slight problem here. Every time I try and connect to my MySQL server (@ 192.168.2.140) I get-
autorun/server/uban.lua:67: Can't connect to MySQL server on '192.168.2.140' <10061>
Any ideas? The server's running on linux, and I may roll this out to many, over-Internet gameservers.
EDIT:
--     Config     --
local host = "192.168.2.140"
local username = "root"
local password = "(fail)"
local database = "bantable"
local port = 3306
local table = "gbans"
Offline Sc00by22
You opened the port 3306? Are you sure that's the correct IP?
Offline LUADuck
1. It's on the LAN, and I've opened the port. And I think I know where my server is :V
Did you set up your MySQL to allow incoming connections from whatever IP you're coming from?
Offline LUADuck
Done, and still not working.
GBan @ ANYHOST has attributes : SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, FILE, INDEX, ALTER, CREATE TEMPORARY TABLES, CREATE VIEW, SHOW VIEW, CREATE ROUTINE, ALTER ROUTINE, EXECUTE
root @ DuckyStudios has attributes : ALL PRIVILEGES
Neither work.
« Last Edit: June 18, 2008, 09:15:22 am by leach139 »
Try connecting with a MySQL client.
Offline LUADuck
1hour, 15 mins remaining (1.5 kbps)
WHAT!?!?!?!?!
« Last Edit: June 18, 2008, 11:07:27 am by leach139 »
